Thread: 1985 250 es electrical problem
    bg77 is offline New to the board Arm chair racerNew to the board
    Sep 2013
    Foley AL
    11
    hello, i have an 85 250 es that ran good until i tried to charge the battery. after i took it off charge it wont do anything but turn over. i had an extra cdi plug and i put it on and it still wont crank. what should i do next change the rectifier? i could use any info
    Michigan
    1,144
    Did you check the main fuse? Sorry I didn't read your post right, I see it turns over. Try a new plug.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Pacific NW
    4,255
    to clarify?
    it started and ran, you charged the battery and now it will spin over but not start??
    Sometimes they'll kick start but not with the starter.
    There IS a funky fuse, looks like a miniature end wrench insie a rubber boot inside a plastic box with tiny phillips head srews.
    Seems to like and hold water but I forget the exact symptoms.
    can you click on:
    service manual
    Do you have spark at the plug or wire?
    Oct 2011
    Burgessville ON
    22
    I second checking that fuse
    MN
    3,263
    Ok let me get this straight so i know where you are at...
    You charged the battery, assuming it was low and the electric start wasn't working or?
    Now it turns over with the electric start but the engine isn't firing correct?
    You got a problem but its not due to charging the battery... And the fuses won't do jack as far as spark is concerned. These trikes have an AC ignition system, seems like we go over this about once a week lately. The ignition system and the battery charging/lighting/electric start system is two completely separate systems! The alternator/stator output to the rectifier/regulator charges the battery, runs the lights, and thats it. The ignition source coil and pulser provide the AC to the CDI and in turn the ignition coil and the spark plug. These systems have to connection to each whatsoever. The fuses are for the DC systems, lighting and electric start only.
    If you need the service manual its available on my manuals website, link is below in my signature. Have a look at the wiring diagram.
    Ok now lets start with what you can do! Pull the spark plug, ground the threads of the plug on the head and crank it over, do you see spark at the plug? If not then you have to start going through the ignition system. Check your kill switch and ignition switch, make sure neither of them are grounding the kill wire, a common problem is a faulty kill switch on the handlebars. Been there done that!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Sep 2013
    Foley AL
    11
    i changed the spark plug and now she runs like a champ again. i should have started with the spark plug i guess. Thanks alot for your advice. ill see if i can post a pic of the old red.
