Results 1 to 7 of 7
Thread: 1985 atc250sx gas cap
    AF79 is offline New to the board Arm chair racerNew to the board
    Sep 2013
    I just picked up a 1985 Honda atc250sx this weekend. The gas cap vent lever is broke off. Are the caps of the different Honda atc's fairly universal size?
    Jan 2011
    Choctaw, OK
    2,755
    Unique to ES/SX. I have a new one I'll sell you for 45 bucks shipped.
    Mar 2013
    Central PA
    2,362
    I always thought the vented gas caps were the same. What's different on them? Just size?
    Because even my 200s has one. I just thought the only ones that were different were like the 200x's with the breather tube caps.
    As long as it broke in the open position I think you'll be fine for now. Because if its off I'm sure you already know that it creates a vacuum and that means no gas to carb.
    Jan 2011
    Choctaw, OK
    2,755
    You may be right to some extent on that Ghost but not all caps will fit or seal that way they are supposed to. I have tried a couple different caps on SX tanks and the opening was different.
    Nov 2010
    Oshawa, On, Canada
    2,123
    I have swapped caps from , es, sx, 125m, trx 125, 110's,
    Probably others too, but that is all I am 100 % sure about.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    May 2009
    S.E. Michigan
    1,251
    You can still buy them new from Honda (using your favorite on-line parts retailer). I ordered and received mine last year and externally, it appears identical to the original.
    The parts catalogs on-line do show that the original cap has been replaced by a substitute part though (gascap currently called out for 250SX is: 17620-HC3-505). Just for kicks, I did the reverse part number search and it comes up as the TRX300 gascap (from 1996-2000).
    And for what its worth: this same part number shows up as the replacement cap for just about all the machines that use that style cap (the big black cap with vent knob on top). I know that the new replacement cap I got fits both my 86 250SX and my 84 Big Red (200ES).
    Last edited by wonderboy; 09-17-2013 at 07:49 AM. Reason: Added comment about interchangability
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by Jason125m View Post
    Plus the ATC200 series(except 200x) the 185 and my Fourtrax 300 4X4 also..OEM part number crosses over on the parts lookups for all of them.
    Pretty standard Honda cap..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
