Tri zinger
My tri zinger with a brand new carb is leaking out of bottem of bowl and did this with other carb also. Only thing i don't know my fuel cap is broken could this cause this? Thanks
I can't just think off the top off my head but maybe the seal on the bowl isn't seated right. Maybe the floats stuck causing it to overflow. Maybe a screws loose or missing. Not really familiar with carbs just off the top of my head.
Just take it off, clean it, visually inspect it, then put it back on and see what happens.
That's Is a brand new one and the first did the same
tri z
I just purchased a tri z and mine is doing the same thing, I have switched carbs also and it just keeps leaking fuel, I know the tri z bikes have a fuel pump instead of gravity flow, is there a chance it has to much pressure and is blowing past my needle and seat?
//ArrowChat Integreation Code
