Is there a hand tool that can make the end of an exhaust pipe wider or do I have to bring it to a shop for that ? If so will Midas do it or who do you recommend ? I am not sure if its steel or aluminum.
♠ 58 ♠▓
▓ ▓Ride 3
I imagine you need that lil 90 degree end to this for this to seals. Call around before you go cracker on the pipe![]()
If your not sure if its steel or aluminum, grab a magnet and see if it sticks to it. Steel it will stick. Aluminum the magnet will not.
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
Thanks for the replies. I went with the supertrapp 633-3401. I am gonna cut the connector pipe in half and use flexible stainless steel hose in between. The can will be mounted with the supertrapp badge facing the inside of the bike. I suppose that connector pipe that comes with the can is steel. I will soon find out. The connector pipe will be slightly less outside diameter so I need to widen the ends of the connector pipe so the stainless hose
fits snug over pipe ends.
♠ 58 ♠▓
▓ ▓Ride 3
