Results 1 to 7 of 7
Thread: what is this?
    Sep 2013
    netherlands
    what is this?
    I'm new, hello all.
    I have a funny little trike here (Netherlands) and wonder if somebody knows where it comes from.
    Greetings, :
    Wouter
    Jul 2011
    Ontario/Quebec
    1,179
    Welcome aboard!!!! cool,,, looks like offroad mobility scooter!! what kind of motor runs that??
    1986 Honda 350X
    1985 Yamaha Tri-Z 250
    Mar 2013
    Central PA
    2,362
    Quote Originally Posted by sp8twn View Post
    I was just about to say that too. Looks like a gas powered mobility scooter. Did you see it in person?
    Also is that a air filter that's coming out on the right side? The black thing. And is that switches on the deck there?
    Sep 2013
    netherlands
    well that's the problem! I bought it without engine. It has a sortof industrial (square welded) gearbox with 2 gearings 30:1 and 19:1 done through 4 shafts and 8 gears, complicated. It also has a differential in the same gearbox. I first thought agricultural as the speeds are low with that gearing, about 6 miles and 10miles/hour max. Later maybe a airplane puller?????? The wide tires make it off road.
    I guess +/- 6.5hp engine max. Guesstimate 70ies. It has two (hydraulic) disk brakes at the back and is heavy. Zero electric components (except engine)
    the 4 things at the foot plate are the motor mounts.
    Question remains WHAT IS IT ?? btw thanks for having me here on this forum!!
    Greetings W
    Mar 2013
    Central PA
    2,362
    I don't have the slightest clue but all I can say is try to look for any names, numbers, anything that you could research it by.
    Oct 2013
    Lake Arthur
    15
    Weird looking little thing, but I bet fun to ride.
    Oct 2013
    Wherever I May Roam
    3,757
    Maybe it wasn't mass produced. If it has no consistent manufacturing marks, you may consider the fact that it may have been home-built, or even purpose built by a manufacturing company to perform a specific task in a factory or equipment yard.
