Thread: 1983 honda 200e electric start issues
    Jun 2013
    Bellingham
    42
    when i try to start my big red it doesnt turn over with the electric start but it makes a weird noise like its trying to do something. one thing i do know is i have the battery hooked up to it while its on the charger and it still doesnt work. idk what the problem would be maybe a bad starter or starter solenoid? does any of this sound familiar? Thanks!
    Mar 2013
    Central PA
    2,362
    Do you have a good battery? Can you test the battery in anything else to make sure?
    Jun 2013
    Bellingham
    42
    i test the battery when its off the charger and it is well over 12 volts but it will slowly loose charge and when it is hooked up to the charger it is over 13. the battery isnt very good btw
    MN
    3,263
    Try running the starter by itself, use jump starter if you have one otherwise a set of jumper cables to a vehicle, put the ground to the frame and then touch the positive to the terminal on the starter, does it spin over? If so then its probably a bad solenoid, which you can test further also. The solenoids usually go first on these, but the starters will burn out brushes and become unreliable as well. The solenoid is an easy fix, and cheap. The starter you can get a rebuild kit for or just replace for about $40.
    But definitely figure out which is the first. Whats the noise its making? Do you hear the solenoid click? Sounds like the battery is done for. Replace it with a good AGM battery! I went through two cheap $40 lead acid flooded cell motorcycle type batteries before i bought my AGM, cost more but well worth it. Check out the ETX15 Big Crank, that fits the 200E as well as my 200ES. Its made a huge difference in cranking power for me.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
