Results 1 to 7 of 7
Thread: cr250 ignition upgrade on my 250r
    Sep 2013
    I just wanted to know what i have to change, does the hole wiring harness have to be replaced. do i have to get a cr cdi box, stator, flywheel and coil
    Sep 2013
    and is the 2001 cr the only one that works
    Blossvale NY
    4,563
    2001 is the only one that readily plugs in.
    I heard recently that Honda discontinued the 2001 CR250 CDI. And since ESR no longer has the CR ignition kit on their website I assume that it's true. There are some folks in the R community working on getting the 02 CR250 components to work.
    The 01 kit consisted of flywheel, stator (no lighting coil) pickup coil, CDI and the corresponding harnesses.
    The kit was kind of pricey at around $700. I can only assume that now that they are discontinued, you will probably pay a little more for a kit if you find one.
    If that's not feasible for you, keep an eye out in the usual places for a good used OEM CDI. Once you get through your newb probationary period here, post a WTB in the classifieds.
    I have 2 spare CDI's but I'm keeping them for my pair of '85 R's..
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    May 2009
    alabama
    68
    what year is your 250r? If you have an '86 model, a CDI for a trx250r will plug right in, there is plenty of aftermarket support still around for the trx
    Sep 2013
    i have an 1985
    Sep 2013
    will a 1986 wire harness and cdi box work on the 1985
    Blossvale NY
    4,563
    Quote Originally Posted by pounder76 View Post
    Actually it does. About 2 years ago, I found out the '85 CDI were unique to '85. And thanks to a friend on here, I figured out that one of my '85 ATC has an 86-later style CDI in it. My wiring harness is not hacked or cobbled together. So, the only explanation I could figure was at some point, somebody installed an 86 ATC wiring harness in my 85.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
