Ok it started raining so I decided to play in mud on the 200s.it kinda was hard to start witch I thought was odd,rode down the road and back home.it stalled tryed to restart and extemely hard to pull.took cdi cover off and metal came out,like a magled up spring?that holds the advanced?together.now the timing piece(with bolt thre middle that goes to cam)does not spinwith motor,but valves move.what happened?hope that makes sence,if not and your a motor guru give a call if you have a min.thanks all,damion 903-830-2422
good luck!
