Page 9 of 11 FirstFirst ... 7 8 9 10 11 LastLast
Results 121 to 135 of 152
Thread: ES-SX-350X Carb rebuild Tutoral
  1. #121
    Jan 2013
    minnesota
    5,911
    Flying, thank you very much for the highly detailed info and the time you put into it . . I’ll just post some general info and try to be brief . . I know you’re a sharp guy and likely know some, if not all of what I’m posting below, so it’s mainly for some others whom might at least find it interesting if not helpful . . I am also aware that you know this particular style of carb very well which is why I have referred others to you when I saw they had a carb issue with one, so none of this will be about me making suggestions to tune this particular carb, especially since I don’t know this particular carb well, plus you have already been there and done that.
    Some of the info will also be irrelevant to most because people are simply not going to change some of the things I mention just to try and reduce the hesitation their engine has which is understandable, so again, some of it is mainly for general informational purposes . . I know that El Camexican is also familiar with some, if not all of the info below, so I’m a little surprised that he hasn’t made a post on the op’s thread at the very least, but I haven’t seen him post much lately so maybe he just isn’t around . . I am also not the most knowledgeable person in the world on these subjects, however, I at least know enough to get by and where to go if I need more info.
    None of the mfg’s are dummies, but on occasion, but all of them, including Kawasaki, have built something that has had one type of quirk or problem in the past, therefore, none of this is to rag n Honda…too much, lol . . Problems like this just happen sometimes . . The mfg’s certainly learn from their mistake and eventually fix them on future models.
    CAMSHAFT
    A cam that has a lot of overlap will idle poorly due to low engine vacuum and a “dirty” intake charge that is diluted and contaminated by exhaust gases that haven’t been completely evacuated from the cylinder, therefore, one of my guesses is, that with this particular bikes combination of ex pipe and ignition timing and compression etc, the cam has too much “overlap” . . Camshaft lobe overlap is affected by a few factors, one of them being the distance between the cam lobes which is referred to as “lobe center angle” or “lsa” for short . . Most stock automotive engines have lsa’s in the 115 to 116 degree range . . This is to make the engine idle smoothly and be more “streetable” with good throttle response, especially in traffic etc . . Most performance automotive aftermarket cams use a lsa of around 110, which is a huge difference . . If all other things are equal on a cam, the one with a lsa of 116 degrees will idle far smoother, and have far more engine vacuum and better throttle response than the cam with a lsa of 110 degrees.
    I would be interested to know what the amount of overlap the 250sx cam has compared to another 250 cc engine that didn’t exhibit this problem which has a non accelerator pump carb . . If the lsa was increased on the sx cam, the hesitation would be greatly reduced if not eliminated if it had a properly working and tuned carb, but that’s going to affect the power characteristics, plus changing a cam is not what most people would want to do to improve this problem.
    ENGINE VACUUM
    The more vacuum an engine has, the better throttle response it will have and the easier it will be for the engine to draw fuel from the carb . . I would be interested to know what the vacuum level is on these engines at idle and when the throttlke is stabbed . . the stabbing test is not a definitive test due to some variables but it still might yield some useful info . . One just doesn’t know unless they try it . . If the vacuum at idle or around 1/8 throttle is less than around 14 hg, an engine can start to exhibit carb related hesitation and or poor idle characteristics.
    CARBURETOR SIZE VS ENGINE VACUUM VS THROTTLE RESPONSE
    In general the smaller the carb, the higher the vacuum will be . . It is possible to run a 40 mm carb on a 250sx and have it not work much, if any worse, than the stock 27 mm carb providing the intake tract size is reduced sufficiently . . This gets a bit complicated and it will reduce power but it will still work . . this concept is exactly the same as the restrictor plates that Nascar occasionally uses . . To this end you could get a piece of pcv pipe that will slip snugly into your carb adapter or the exit side of the carb and see what affect that has on throttle response . . you can also check the engine vacuum before and after . . Of course you would need t rejet your carb and obviously this will reduce peak power but it might still give some useful info, and if it does significantly reduce hesitation, and someone uses the lower end of the operating range most of the time, it might be a viable solution to their hesitation problem.
    IGNITION TIMING
    If an engine has insufficient amount of timing it will have both a hesitation and will spit back out the carb . . This is easy to test if someone wants to . . Just reduce the timing on your engine by 10 degrees and check it out . . With this in mind, I would look at the ignition pick up and see if it can be easily modified to advance the timing by 4 - 6 degrees . . This amount is definitely enough to alter the performance enough to feel, however, it’s not what could be considered excessive . . If this reduces the hesitation and the engine doesn’t ping, it seems like a simple, partial cure.
    EXHAUST SYSTEM FUNCTION AND DESIGN
    In general, the exhaust pipes are not just a way to route the exhaust gasses to the rear of a vehicle, they are also intended to perform a function called “scavenging” which basically creates a sort of vacuum effect that actually helps pull the intake charge into the engine . . This affect is more pronounced on vehicles that have multiple cylinders with individual pipes that converge/merge together at the end where they exit into one single large tube . . In fact here’s a couple short, super low budget, simple tests, that visually shows the vacuum affect created by exhaust scavenging.
    https://www.youtube.com/watch?v=pDQXsfeZGwk
    https://www.youtube.com/watch?v=yMyKv_P80eI
    https://www.youtube.com/watch?v=W7lbTcdaYpE
    CARBURETOR SIZE
    Based on all the info you have provided along with other info gathered, it is my guess that to reduce the hesitation, it is best to stick with a carb that is between 25 and 33 mm for this particular bike in box stock form anyway . . There is an oval bore Chinese pumper carb with a 27 mm outlet which would make it around a 25 mm carb . . The one I posted earlier was claimed to be a 30 mm but that might have been the outlet size . . If it is, then that carb is around a 27 mm . . It’s a bit hard to tell the true size of some of these because the sellers don’t always post the exit size and instead often just state a mm which in many cases I have seen is incorrect . . Either way, these seem to be in the correct range for this purpose.
    THROTTLE RESPONSE TEST
    Posted a few posts above this one.
    LEAN CONDITION TEST
    CARBURETOR HEAD/TOP CLEARANCE
    That’s a very good description . . I will look for a top that might have an elbow on it, there are some . . Another option is to have the end of the cable modified by having an elbow installed . . If you look at the bike below, it looks to me like it might have a Mikuni on it . . I have no idea if they used an elbox on top of the carb though . . The carb is also mounted square to the ground . . I don’t remember if the 250sx carb is mounted at the same angle or if it is angled upward . . Either way, if the carb used, is angled upward, it would have a little less bend in the cable which might make it a little easier to use a straight cable on it . . You would certainly be one of the best judges of that since you are very familiar with how much head clearance they have for the carb.
    CHINESE CARB QUALITY
    I for one am not a fan of Chinese made parts in general, however, of the posts I have read regarding the Chinese made carbs, most were positive . . There were a few that were initially negative, however, it was later determined the either the float level was off, or the needle had debris that came from the persons fuel tank stuck in it etc . . I’m sure some of them simply don’t work well for some reason or another, but judging from what I have read, in the majority of the cases they seem to work just fine . . If I remember correctly, they may not use the exact same jet numbering system the Keihins use but regular Keihin jets work in them.
    Also if I recall correctly, Damon told me that some, if not all of these carbs, are the exact same model that are used on some production Chinese motorcycles, therefore, in light of that info alone, I would guess that they should be fairly decent considering there are around 100 gazillion motorcycles in China but that’s just my guess.
    ACCELERATOR PUMPS
    Just buying a carb with an accelerator pump does not mean that is going to work better without being properly tuned . . One of the complications with carbs that have accelerator pumps is that one size does not fit all . . in other words, the pump may squirt too little fuel or too much . . it may also not squirt fuel long enough or it may squirt it for too long, and unfortunately, unlike the accelerator pump on most if not all aftermarket automotive carburetors, the pumps on a motorcycle carb are rarely, if ever, adjustable . . This means that if the pump on the carb needs some adjustment, you will likely have to modify or make some parts to do that with.
    One example I heard of regarding problems with accelerator pump carbs, was related to the Keihin FCR model . . The problem is apparently so common, that Boysen makes a $120.00 kit with an adjustable jet to cure this with . . I read on the net that one guy was smart enough to simply buy a $5.00 jet the size he needed to fix this prob on his carb.
    The point being, don’t expect any carb with an accelerator pump to have the pump setting be ideal for your bike right out of the box . . You might get lucky…you might not . . This being said, I’m guessing [hoping] that the ones on the small Chinese carbs will be pretty close for this particular app at the very least.
    Please feel free to mention any errors . . I have no edit button so once it's posted I can't correct it.
  2. #122
    Jan 2013
    minnesota
    5,911
    ok, I went window shopping today and eventually came up with the items below . . I started thing about hesitation off idle and suddenly thought about constant velocity carbs like the original 750 hondas had so even though they were not considered a performance carb at the time, I still figured that it would at least reduce or eliminate the hesitation when the throttle is stabbed simply because the slide will not open until the engine has sufficient vacuum so they are a great carb for people that have an engine with this type of prob but don’t have the self control to keep from stabbing the throttle.
    well during my search, I not only cane upon standard cv carbs, I also came across some that have an accelerator pump so what the pump does on a cv carb is force some fuel into the engine so it builds revs faster which increases vacuum which in turn opens the slide sooner than a cv carb without a pump so there is far less delay between the time you open the throttle and the time the slide opens . . not only this but these are spigot mount like the factory 250sx carb . . if they are a hair too big for it then just buy a a bigger carb mount from mikuni for $15.00 . . they also sell ones with a 15 degree downward bend if needed . . but wait…theres more, as an extra added bonus, it has a side mount throttle cable so the concern for headroom is no longer there…oh, oh…and they are only $57.00, but hurry while this limited time offer lasts . . the stock 250sx cable might also work.
    this should be 30 mm bore with actual 27 mm flow oval bore . . it looks like it shows two different throttle cable bracket types . . contact to confirm if interested . . $57.00
    http://www.ebay.com/itm/Chinese-Go-K...-/261912361112
    Heres a couple more
    gy6 250 and cf250 cv type no pump
    http://www.ebay.com/itm/KEIHIN-30mm-...-/111539386490
    gy6 cv type with pump fits 150 cc
    http://www.ebay.com/itm/Keihin-Carbu...-/221449096781
    Ok, here’s what I have so far on carb top elbows . . The tops on both of these look like they will fit the 30 mm carb I posted, plus they are all Keihins so the thread pitch etc should be the same . . Of course the atc125 carb top is discontinued so to get one, a person would have to buy a complete orig carb or a Chinese one . . The tops could be swapped and the carb the top was scavenged from can probably be resold on Ehay fairly quickly for 1/2 price.
    This elbow may cause the inner cable of the throttle cable to be too short . . If it does, a new inner cable can easily be made.
    Original Atc125 carb
    http://www.ebay.com/itm/like/3611874...lpid=82&chn=ps
    Chinese carb
    http://www.amazon.com/Carburetor-197.../dp/B00AWBNQ0I
  3. #123
    Jan 2013
    minnesota
    5,911
    ok i can see that the cv carb has two different locations the cable could be mounted . . the rear cable mounting bracket could be removed to reduce weight and enhance its beauty.
  4. #124
    Jan 2013
    minnesota
    5,911
    at least i think that might be whats going on . . a little hard to tell for certain
    i have no edit button
  5. #125
    Jan 2011
    Choctaw, OK
    2,755
    Boy Barnett, when you get after something, you get after it. Interesting prospects and I appreciate all your efforts. What I would like answered is why do some of the stock carbs stall on stab and some don't. What is the common denominator? There are lots of stock ES/SX carbs out there on our beloved machines and I would guess that most of the owners would rather just stick to their trusty old QA series carb including myself. I'm not saying that identifying a suitable replacement is just as important because it is but for those carbs with the stabbing problem finding a solution to correct the problem as inexpensively as possible is what I would like to focus on at this point. Reason being with the steady amount of carbs I do, when I rebuild a carb with the stabbing problem, I would like to apply the fix during rebuild and return a perfectly operating carb to its owner is my goal. I would like to gather a systemic plan to troubleshoot and identify the root cause of the stabbing problem. Could it be something as simple as changing a jet size or even looking at the linkage to see if that has something to do with the problem. At this point I think going back and starting over is the way to go but I need a carb identified with that problem to be used stickily as a control specimen so if anybody has a carb they would like to offer up that has that problem and the more severe the better would be greatly appreciated. It wouldn't be to keep it but simply to borrow it for troubleshooting.
    Don't stop what you're doing Barnett as that information is valuable and who knows. You may just find the perfect replacement carb. Those Chinese carbs sold on Ebay have had mixed results mostly bad. I've had guys tell me they bought one and with everything they did, could not get the motor to run right among other issues like cable fitment but some have reported the carbs worked perfectly so that has me baffled as well. Anyway, keep on with your research. If anybody reading this has anything to contribute please speak up. The question is.....what is causing some ES/SX carbs to stall when the throttle is stabbed at idle?
  6. #126
    Jan 2013
    minnesota
    5,911
    lol, yeah, im one of those that doesn’t accept failure providing it makes sense to continue on to find the problem . . as john lennon once said. There are no problems…there are only solutions.
    I understand your focus and your goal and im with you that it would be nice to find the prob and be able to keep the bike original, but I can only throw random suggestions at you at the moment and it would require a lot more detailed info to maybe narrow the cause down . . it would also help to have a carb in my hand to see what they did but obviously that’s not practical . . I did notice your post earlier that you said you had not tried to go big on the pilot to yet to see if that would help . . unfortunately I haven’t had time to read thru your entire thread so other than that comment, if its correct along with the others you posted in your reply to me is all I know that you have tried.
    I guess one question would be why haven’t you tried a big pilot to see if that helps?
    I know you said that you though one might be rich because of it spitting back and if everything else was in perfect shape as far as compression and timing etc goes, that certainly sounds to me like the most likely cause but with an unknown cause like this, there is little I would rule out.
    I though you said that your carb also did this so if that’s the case, then why don’t you experiment on that? . . I know that seems like the obvious thing to do so im guessing there is obviously a good reason.
    I would guess that unless your bike ever ran without a hesitation that it would not be a good candidate to use but I would guess that you probably had tested other sx carbs on there that did work well so I really have little to suggest at this point especially with all the unknown factors.
    The dream situation would be to have an nos bike or close to it so you have an ideal baseline but since that’s obviously not possible, just having a bike that does run good is the next best thing to test a carb on . . its obviously a matter of eliminating as many variables as possible.
    For starters, I would slam a big pilot in a known problem carb just to see what it does . . yeagerb actually suggested that to the op of the spark plug thread whom is also the one that posted the carb question for you earlier . . it is unknown if his bike ever ran good while he had owned it so that part is not a help and he has not yet tried a bigger pilot jet, so hopefully he does and hopefully it fixes it and hopefully that is the cure for all carbs that have this problem.
    As to why one carb does it and another doesn’t if they are both jetted the same and the slide and butterfly are both timed the same would suggest to me that it might be caused by casting flash in passage most likely an air passage like one of the ones in the carb throat but that seems unlikely to me but until the cause is determined, anything is possible.
    Also, if this problem is really huge, I would think that it would have been resolved thru warranty when the bike was new because I cant picture someone buying a brand new bike and having a huge problem with it and not having honda correct it and if this is the case, it seems reasonable to guess that none of these had a huge problem because it should have been fixed . . if one assumes this, then it seems reasonable that something has changed in the carbs that have this problem and if worn parts are eliminated as a cause and all the jets are clean etc, it seems that it would point to a partially blocked passage again and in the ones in the throat of the carb don’t have removable jets, it’s a bit hard to tell with those . . if there are plugs on the outside of the carb for some of the other passages then these could be drill out and replaced after the passage is inspected etc.
    As ridiculous as my wd40 test may sound to some, I can assure the doubters that they do often yield valuable info . . not all tests need to have $10,000.00 worth of scientific equipment to be useful so I would actually try that on the next one . . as you obviously know, you really need to determine whether its caused by a lean condition or a rich one first.
    Another one you could try that may or may not yield useful info is a to take a timing light and connect it to the bike and point it at the carb throat in a fairly dark room and you should be able to see if and when the carb is getting gas . . at the very least the effect is fun to see . . but I can tell you that this is a good diagnostic tool for checking the accelerator pump action vs the time the fuel begins to flow out of the boost venturis . . I actually had a video of this showing an engine that bogged because the accelerator pump quit delivering fuel before fuel was drawn from the boost venturis which is a common prob with big cam engines because they have low vacuum at low rpms which is what I mentioned in my earlier post.
    I would love to have a bike and a few carbs to toy with because I like solving problems like this . . I do it often on automobile engines because I build a lot of those and repair and restore and sell old muscle cars for a living . . if I lived near by and you had the bike and carbs I would be more than happy to come over and try to help if you wanted, but I really think that with a known bad carb and a known good one, and some spare time, which is hard to come by for many of us, im confident that you will figure this out on your own, but im certainly more than happy to keep making some type of suggestions if you want but I would give the bigger pilot a try to start with as yeagerb and someone here also suggested.
  7. #127
    Jan 2013
    minnesota
    5,911
    well this makes little sense, but theres probably more, lol.
    "I know you said that you though one might be rich because of it spitting back and if everything else was in perfect shape as far as compression and timing etc goes, that certainly sounds to me like the most likely cause but with an unknown cause like this, there is little I would rule out."
    should read
    I know you said that you though one carb might be rich because it was spitting back when you stabbed the throttle, and if everything else was in perfect shape as far as compression and timing etc goes, that certainly sounds to me like the most likely cause but with an unknown cause like this, there is little I would rule out.
    yup...still aint got no edit button.
  8. #128
    Jan 2013
    minnesota
    5,911
    oops..."thought" not "though" . . ok, guess i better go to sleep
  9. #129
    Oct 2013
    Woodward OK
    88
    That's basically a splash shield that helps keep fuel around the main jet while riding on rough terrain.
    Did you do a compression test yet?
    Have not done a compression test on it yet, didn't feel that I needed to. Has plenty of resistance on the kicker when I kick it over, and starts / runs great with no smoke or issues with power.
  10. #130
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by mayhem17 View Post
    Ok that’s good but on my bikes, I have a file for each one and noted everything I did and the approximate hours on it so I have something to look back at if I need to . . In your case, I would do a compression test even if it was a brand new bike . . One reason for this is that if it starts to run bad later on, I can take a compression test and easily, instantly see if there is a problem there or not . . Plus it will give me a rough idea of how fast it is wearing out.
    The more compression you have, the more engine vacuum you will have, which in turn increases throttle response [reduces hesitation]throughout the entire rpm range . . Increasing compression will also increase throttle response because of the increased power the higher compression gives it, and both this increased power, and increased throttle response, will be throughout the entire rpm range
  11. #131
    Aug 2006
    Texas
    997
    Thanks for the writeup and pics! I'm rebuilding the carb for the 2nd time on my '85 350x due to a problem with it only running with choke full and halfway on. Choke off, it won't run. I found that the pilot screw didn't have the oring in the proper location...it was in the "groove" where you specifically said there shouldn't be an oring there. Thanks for that info! Also, mine doesn't have a main nozzle or primary jet. The hole for the main nozzle isn't even drilled through into the main air passage and the hole for the primary jet isn't threaded, so...not sure what to think about that. I hope it will run like it should after finding this "problem". Thanks again!
    84 Honda 200ES Big Red
  12. #132
    Jan 2011
    Choctaw, OK
    2,755
    You are correct Longbed in that the 350X does not have a primary jet. Neither does the QA04 or the QA09 (TRX250) so just ignore that. Usually when a carb wont run with the choke off, there is a jet that's plugged but it could also be a vent that's plugged. If you look under the cap, on both sides of the slide there are four holes, two large and two small. The large ones are the vents for the bowl but the other two are the vents for the passage ways that feed fuel through the various circuits of the carb. Be sure to spray carb cleaner through those holes and blow them out real well. I have tossed a few carbs because those passageways were blocked and no good way of reaming them out othr than drilling the brass plug balls they put in after the passages are drilled. Just know, every hole should blow through to somewhere else so do the best you can to clean them out. I have X carb bodies if that one fails to work right. Is it an 85 carb or 86? Look on the rim of the bowl under the hose nipple QA05 is 85 and QA10 is 86. It does make a difference when you install a rebuild kit as the slow jet is too small for the 86 carb.
  13. #133
    Aug 2006
    Texas
    997
    It's an 86 carb...and this is news to me! 3 of those 4 holes are clear, but one of the smaller holes(the one that doesn't have the brass piece) is stopped up. I straightened a paperclip and put it in until it bottomed out, but that hole is still plugged. Is there another angle I can go through it at?
    *edit* I followed this passageway going by the casting and it appears to "empty out" into the hole that the primary jet would have been if it were equipped. So am I correct in assuming that this hole is not used since the primary jet is not used? Also, rebuild kit came with a 42 slow jet(used a 42 in last rebuild also) but looks like this is too small and will need a 38, right?
  14. #134
    Jan 2011
    Choctaw, OK
    2,755
    Are you referring to the vent hole? If so, yes that vent hole is still used but it changes direction at the bottom of the vertical hole. The vertical hole dumps in to the passage that runs from front to back. If you look at the front and back of the venture, you'll see holes on both ends. That horizontal passage also feeds the choke valve hole so blow through every hole you can find.
    As far as the slow jet, the 42 jet is too small for the 86 carb. Reuse your old jet #45. If you use the #42. it will be too lean at idle. I about smoked a rebuilt motor. Initial engine start, it idled about a minute before my head pipe was glowing red. That's when I learned the difference between the two carbs and the rebuild kit.
  15. #135
    Aug 2006
    Texas
    997
    I've added a picture with the arrow pointing towards the hole in question. Ok...looks like I need to get a 45 slow jet then. I don't have the factory jet because I must have thrown it away when I did the last rebuild(using the 42 jet). Also, the main jet is 138. Is that ok? Uni filter in stock airbox and DG full exhaust, otherwise stock.
