Results 1 to 3 of 3
Thread: rear sprocket question
    Sep 2013
    indiana
    7
    I just noticed that my rear sprocket on my 200x has a small anmount of side to side wiggle to it. Is this normal. The nuts that hold it on are tight. It looks like the studs that go into the sprocket spider move with the sprocket. O
    Sep 2013
    indiana
    7
    I was hoping you guys would have some input on this. I've noticed the movement but doesn't seem to affect the ride. Just curious if this is a problem or if this is normal
    6,808
    Nothing to worry about if its just a little loose. If alot loose then you would need a new sprocket hub and possibly a new axle
