Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: 200s engine question.
    Sep 2011
    New Castle, PA
    1,134
    Quote Originally Posted by MonkOFox View Post
    I don't think so. The last picture on #7. There is a hole that a little tiny oil hole plug is supposed to go into (on the lip of the cylinder body). Was just wondering why it's there and why it needs to be plugged. I already ordered it was only like ~2 bucks I think.
    There is an oil port that brings oil up and into the center of the cam, and the only way to make that port is to drill from the top of the cylinder. that plug plugs the spot where the started the drill, and it directs the oil flow into the cam. It needs to be there, or else the cam wont get an oil.
    Gone:
    MonkOFox's Avatar
    MonkOFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    texas
    264
    Ah ok. I was just wondering what it was there for. Thanks for the info kb. You too rg.
    I'm just going to take the pull start off to align the marks like the manual says. because later on it says to align the f mark up before you put the stator? on. So I'll just shimmy something in there to keep it on the dot.
    Thanks again!
    1985 200S - fixer upper
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Had to order the little dowel pin that goes in the cam shaft that lines up the stator : (. Oh well. Hopefully Monday I can have it all together and ready to pull the starter!
    This is the part of the manual after you put on the pulse generator cover:
    When it says to pour, I just take the cap off of the valve cover and pour in there right?
    Also when they refer to 'journals' that's these right (the big black arrows)?
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Should have my oil hole plug, cam dowel pin and exhaust gasket in tomorrow hopefully. I was just kind of bumping this thread to get clarification on my previous reply. Probably going to change the oil (Valvoline 10-40 ATV oil). Going to clean the oil filter/pump too. Now, the motor takes about 1 quart of oil. Do I pour the oil into the valve cover (to wet the lobes) in addition to that?
    Thanks again,
    Justin
    MN
    3,260
    I would definitely pre-lube the head. I generally fill the area under the cam and then give the rockers and everything else a good splash of oil to protect it on the first startup.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Awesome, appreciate the tips! I got some inner tubes for the rear tires... Do I need to set the bead, or not? I was kind of worried about going to 15 + psi to set the bead so I just put what was needed and didn't make it pop on.
    MN
    3,260
    Lube em! I use some dish soap on the bead of the tire and on the wheel, makes em slip right in place with a lot less pressure, but you are going to have to air them up farther to pop the bead into place.
    Mar 2007
    Texas
    5,045
    engine build lube works great for initial startup. that is why it was made.
    ________________
    https://www.mikesatvfix.com
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Never heard of engine build lube. I bought some Moly grease. Going to put the grease on the journals (and their seats) and the cam bushing. Going to put the Valvoline 10-40 atv oil in the cam oil pocket and use an oil can to put some on the valve springs, rocker arms and lobes. Thanks for all the info though. It's funny because when CJ said lobes go down I vaguely remembered putting them up in my buddies 200x and the cover not wanting to seat.
    Also found a good video on youtube about adjusting the cam chain tension. If you unscrew the little screw out of the tension nut, you can get a 3mm screw with a .5 pitch and thread it into the adjuster and push it up and down to make sure the spring loaded mechanism isn't all gunked up. Pretty neat.
    MN
    3,260
    I have heard of and used the build lube... But i generally only use that for new parts, example, replacing the cam with a brand new one... If i am putting the parts back in that came out, aka they are seasoned parts, i generally just give everything a good soak in oil, its only going to run a short period before oil flow reaches it anyway.
    Another thing i do if its electric start, i will pull the plug and leave the fuel off and crank it for a few 3-5 second intervals to prime the oil pump and get oil started up through the motor, then go to fire it up and run it. That helps prevent everything running at a higher RPM dry.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Awesome, yeah I'll probably take the plug off and gas and give a few pulls to get some oil flowing. I was hooking the rest of the wiring harness and came across two wires that seem to be just plain old ground wires but wasn't sure.
    There's this one:
    I saw it one of the pictures in the manual and can confirm that it's hooked like that.
    But there was also this one:
    I'm guess that's where it goes, it was bent and stuff. Here is a zoomed out picture so you can see where it runs to:
    Is that where the second wire goes? Bolted to the chain guide?
    I'm gong to pick up a new spark plug on the way home (what should I get?) I have a DR8ES-L I believe. Are there any super awesome spark plugs out there that I should know about? Have to run and get some 93 gas as well and then I can try to start it! After it idles good, I'm going to put on the chain and change the oil.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    I'm just going to leave it there, it has to be somewhere down there, it's long as hell ( the wire ). Did some reading and apparently NGK is best (what I have though it's all dirty and has been sitting in the cylinder for about 3 years). Going to get some air filter oil and get the air filter all ready to go. I think it's a moose (yellow with faded blue lettering).
    Was going to try last night but wanted the gasket maker to fully cure.
    MN
    3,260
    Yep, that ground wire is fine, leave it there.
    As for the plug, definitely stick with the stock NGK, runs the best on them!
