Page 7 of 7 FirstFirst ... 5 6 7
Results 91 to 103 of 103
Thread: Tri-z PowerValve
  1. #91
    Mar 2013
    Baldwin, Wi
    603
    I've been swapping suspension back and forth on this thing depending on where i ride for the past 2 years. It's time to just build a second. #1 TT/Ice racer #2 will be a trail/dune machine. I've got all the parts needed the frame was my only setback. So let the fun begin. I cut off all the unneeded mounts for the race trike and i'm fixing the foot peg mounts.
ID:	248411Click image for larger version.
ID:	248412Click image for larger version.
ID:	248413Click image for larger version.
ID:	248414Click image for larger version.
    85 Tri-z Basket Case
  2. #92
    Mar 2013
    Baldwin, Wi
    603
    Little practice out on the ice yesterday.
    https://www.youtube.com/watch?v=qjeB...ature=youtu.be
  3. #93
    Mar 2013
    Baldwin, Wi
    603
    Couple more goodies.
ID:	250260Click image for larger version.
  4. #94
    Mar 2013
    Baldwin, Wi
    603
    Raffa foot peg mounts welded on, unneeded mounts ground off, fresh paint and shes ready for a frame swap. All 3 hubs and the rad mounts will get this same blue any little parts will get shot with black. Gonna hit all aluminum on the buffing wheel. Mount up the studded tires and i'll be ready for ice racing season.
ID:	255748 Click image for larger version.
  5. #95
    Mar 2013
    Baldwin, Wi
    603
    Racing from Haydays this fall in MN. I got 3rd both days behind Daryl Rath and Lynn Sather.
    https://www.youtube.com/watch?v=WYIB...&feature=share
  6. #96
    Mar 2013
    Baldwin, Wi
    603
    Bye Bye red frame.
  7. #97
    Las Vegas, NV.
    2,532
    I like it, even though it's looking a bit Suzuki-ish!
  8. #98
    3Z with Fangs! is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2018
    Virginia
    184
    It's going to be sweet man!
  9. #99
    Mar 2013
    Baldwin, Wi
    603
    Current Flavor.
  10. #100
    Mexico
    9,018
    Looks mean! What’s the aluminum thing on my throttle side of the bars?
    It sucks to get old
  11. #101
    Mar 2013
    Baldwin, Wi
    603
ID:	257787 Click image for larger version.
    Little brake reservoir made on my lathe. I run 09 GSXR brake master and clutch perch.
  12. #102
    Sep 2019
    Westminister mass
    Hey. Beautiful bike you built. Can you please tell me what forks those are, how much have you shortened them, and what triple trees you are running?
  13. #103
    Mar 2013
    Baldwin, Wi
    603
    85 tri-z cases
    86 tri-z transmission
    85 YZ250 crank shaft Hot Rods connecting rod & bearings
    85 YZ250 Cylinder (ported & polished cylinder)
    Sprock Head
    Wiseco YZ250 piston 68.5mm
    38mm Keihin PWK
    Boyesen Power Reeds
    LRD Pipe
    Unknown silencer
    Complete chassis All Balls bearings
    2001 CR125 Forks
    Works quadcross rear shock
    Lonestar +2 axel
    Metal Tech +3 Swingarm Banshee round carrier
    Hall Performance Triple Tree's
    2001 CR125 Forks
    2001 CR125 Froks -6"
    Billet Thermostat Eliminator
    Unhinged ATV Foot Pegs
    250R Front Hub
    10" 250R Wheel
    Hoosiers on All 3
    Adjustable Rear Lowering Link
    Top Mount Tank
