Results 1 to 9 of 9
Thread: 250SX with inverts????? Very interesting!!
    Jul 2011
    Ontario/Quebec
    1,179
    1986 Honda 350X
    1985 Yamaha Tri-Z 250
    Mar 2013
    Southern Wisco
    96
    That's quite the driveshaft angle, can't imagine that would hold up very long. Imagine the vibration it would put out!
    cbx1170's Avatar
    cbx1170 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Phoenix AZ USA
    224
    The top clamp is not in the correct spot to hold. And they are angled together at the bottom??? not parallel at all???
    TIME TO STRETCH THE RODS
    ROLL THAT BEAUTIFUL BEAN FOOTAGE
    Tucson
    1,652
    Quote Originally Posted by cbx1170 View Post
    Good eye, didn't notice it at first!
    Sep 2011
    New Castle, PA
    1,134
    yeah when you look at the first pic, they make a kind of shape like this:
    Its a nice effort, but a botched home made job like that wouldn't last long under normal conditions.
    kinda seems like they drilled the holes out wrong, and the tops sit out too far, or the axle is wrong, idk. either way, not good, unless its just the picture and they are actually straight, which i'm skeptical of lol
    Gone:
    Las Vegas, NV.
    2,489
    It could be an optical illusion due to the taper of the fork legs.
    Apr 2012
    USA
    4,133
    Interesting trike, kind of sad that the rest of it is pretty ugly, the front end is about the only thing that looks fairly good (the fender is spray bombed??).
    Carthage NY 250r rules
    2,355
    It looks like the front axle is to narrow and they pulled them together to get it to work.
    250r rules
    N/A
    5,818
    nothings done right on those. if you want inverts on a 250SX and do not want it raked like a chopper buy mine already set up for YZ80/85 forks.
    mine are on ebay and forsale on here. Not gonna use them.
