HERE IS A VIDEO OF ALL THE SMOKE
85 Honda 250sx- STILL IN PIECES!!!
84 Honda 185s - traded off
85 Yamaha 225dr - parts machine for now
83 Yamaha tri-zinger 60cc - my sons first 3wheeler. $300 for zinger, $4000 for a broken leg, memories for a life time - PRICELESS
85 Honda Big Red 250es - traded off
86 Honda 250r - traded off
85 Kawasaki Tecate - new toy
84 Honda 200m - super clean puttin around toy
I did pressure test that sucker if it all was okay buy a pocket full of jets and dial that sucker in
I was born to ride atc
current atc's 85 250r (the big fast one) 85 200x (old reliable go anywhere machine)
past atc's 1970ish atc 70(still miss it) 83 110 (still miss it)
Still hard to say because you aren't moving. You need to have someone take a video of you going through all of the gears. It does smoke more than mine at idle and I am running 36:1 927 Maxima castor (typically mine clears out after a couple hard blips of the throttle). I still think if you have some issues in the motor; rings/seals/etc.
Have you had that smokey pos out for a real ride yet? The previous owner could have run 20:1 in that thing and the pipe and silencer my be coated in the interior. If so it would take a real ride to burn that goo outta there.
Shart Guard .......Use it !
Pink Powerwheels Barbie trike
1985 Crash and Burn champ
No sure havent, hopefull ill get to put a little more time on the seat this week
Opened the silencer up. Nothing in there. I dont mean a little bit , absolutely nothing. Packed it up so maybe that'll make a difference in the sound.
SO, I THINK THE AMSOIL MADE A BIG DIFFERNCE , RUNNING AT 40:1. ALOT LESS SMOKE
JUST A SHORT VIDEO BUT YOU CAN TELL THERE IS A DIFFERENCE
ALSO GOT THE BUFFER AFTER THE TANK...LITTLE CLEANER
BFORE
AFTER - JUST USED SOME TURTLE WAX-COLOR BACK AND ONE OF THOSE $4 BUFFING WHEELS THAT YOU ATTACH TO A DRILL FROM HARBOR FREIGHT
THANKS FOR EVERBODYS HELP
you need to do a pressure test and a compression test.
IF it passes both, then you can look at jetting and oil ratio.
That's alot of smoke...not normal.
You may have worn rings/piston or a scored cylinder.
Marc
You think it still smokes too much?
Have you taken it on a long ride yet??? I dont think its a ring problem. Its a 2 stroke with the oil in the gas. bad rings can make smoke on a 4 stroker where the crank case oil is getting into the combustion chamber. keep an eye on the gear oil level. If its going down after a long ride that could be the smoke problem. Gear oil getting into the crank case and burning with the fuel. If you havnt been on a long ride yet and really gave it a good chance to clean out, you should try it. I always try the easiest things 1st and work up from there.
Got to ride it pretty hard for about an hour this evening . No more smoke trail!!! Time to make a trip to the red river
Well its good to hear its gettin better. You fixed it the easy way. Old guys might know sumpin.
I guess some of you old turds just might know sumpin.
Thanks again.
