Thread: 85 atc 250r output shaft
    Aug 2013
    Mazomanie, Wisconsin
    24
    ok guys I have a question. on my 85 r the output shaft has been rounded off due to prior damage when the sprocket bolt snapped which resulted in the sprocket to slide off the shaft which rounded the end just a little. I was able to use a dremel and clean up the burrs on the end of the shaft. the rest of the splines were fine. about a week ago I was riding it and a few times it felt as if the clutch was slipping. last night we were doing test and tunes for drag racing Saturday and now it wont move at all. we tore it apart and realized that the entire output shaft has been completely rounded and now spins inside the sprocket.
    So I guess the question is first. Is there any way I could make it work for this weekend at all. I have a few ideas but it is a shot in the dark. and secondly in order to replace the shaft will the case need to be split or is it accessible with the clutch cover off.
    Carthage NY 250r rules
    2,355
    Yes you will need to split the cases to change the shaft.
    250r rules
    Blossvale NY
    4,563
    No quick fixes that would for sure adequately hold other than welding the sprocket on. I'm not a fan of that though unless you are in a major bind. You would have to cut off the sprocket then to split the cases and replace the countershaft. A little more PIA than I would want to deal with for one more weekend of riding.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Aug 2013
    24
    Thanks guys. It looks like I'm going to be racing with four wheels this weekend. The thought of welding crossed my mind but I don't know how it would effect the properties of the metal being hardened or not. Looks like it is a prime opportunity to build it.
