Thread: Will Banshee rear hub fit on tri-z axle.
    tmhcycle's Avatar
    tmhcycle is offline At The Back Of The Pack Arm chair racerFirst time rider
    southern cali
    151
    Looking to see if banshee rear hubs will work on my tri-z. Also would the banshee or blaster rear axle, carrier, sprocket,disk assembly work on a tri-z. Has anyone tried this
    oile's Avatar
    oile is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2012
    kansas
    600
    Yes they will
    New2Tri-Z's Avatar
    New2Tri-Z is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2012
    Redding, CA
    380
    Yes the hubs will fit the axle and you can run the banshee 4/115 wheels. Thats what most guys do to get better wheel options. I know the banshee and blaster axle will work in the Tri Z carrier. I am pretty sure if you used the banshee carrier then you can run all the banshee components (caliper, sprocket hub, rotor hub, etc..). I am not 100% sure on that though. Check out this thread as I know you can find some answers in there http://www.3wheelerworld.com/showthr...ts+interchange
    Currently Owned
    1986 Yamaha Tri-Z 350???
    1985 Honda ATC 70
    1985 Honda ATC 250R
    2006 Suzuki LTR450
    2005 Suzuki LTZ400
    2005 Polaris Predator 50
    2004 Polaris Predator 90
    2-Honda Trail 90's (need to be brought back)
    Feedback Thread http://www.3wheelerworld.com/showthr...-for-New2Tri-Z
    May 2013
    Quebec, Canada
    134
    I think the blaster axle is shorter about 3 inches, banshee axle fits perfect that's what I have on my z, the only difference is that there are more threads for the two locking nuts on the sprocket side, the z locking nuts do fit but don't cover all of the threaded part. I used banshee nuts which are a little wider to protect the threads from damage. I'm using the stock tri-z carrier & brake assembly, sprocket hub from a blaster or banshee (not sure which), axle & locking nuts from a banshee and wheel hubs from a blaster(same as z hubs).
