Results 16 to 30 of 68
Thread: 200s compression really high.
    MonkOFox's Avatar
    MonkOFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    texas
    264
    Ok, so I took the motor out and took the spark plug out and the cdi stuff. I pull on the starter and it was smooth as can be. So I was like, hmmm. So I put the spark plug back in and viola, hard to start again and really really hard almost knocked the motor off the table not expecting it. So I tore it down anyways and there are no obstructions, everything looks good...
    Here are the pictures I took:
ID:	178702Click image for larger version.
ID:	178703Click image for larger version.
ID:	178704Click image for larger version.
ID:	178705Click image for larger version.
ID:	178706Click image for larger version.
ID:	178707Click image for larger version.
    Could the dirtiness on the valves/piston cause it? The timing looked good. I did the T/O thing and then the F and lines on the pulse generator and the part that slides on the cam, stator, that's it. Now, I did mark the letter and not the line with a circle above it, could 1 tooth off or so make it harder, that much?
    Also, I inspected the tappets and they were compressing the valves like the should, even when the spark plug was in and harder to pull. I'm confused... With the valves opening and closing that compression shouldn't be that high. Don't even think I could kick start that thing...
    Thanks.
    1985 200S - fixer upper
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    I cleaned the valve... combustion chamber and the piston:
ID:	178709Click image for larger version.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    I'm starting to think it has to be the valve clearance. I'm going to adjust them closer. Maybe the valves aren't opening enough. It's pushing the pin and the spring is compressing though. That's the only different part I have as well.
    What is the PSI??
    Was the rubber plug behind the cam journal installed?? If not the cam doesn't get enough oil.
    You are running rich, def carboned up...........
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Yeah I never cleaned it before. And didn't adjust the fuel mixture screw list supposed to. I'm going to adjust the valve clearance and hopefully the compression is so high. Then I'll test it. If I can't turn it over, lean or rich is the least of my worries. I'll post pictures of how I reassembled.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Here are the steps I took:
    Put the bushing in:
    Put the plug in:
    Oiled everything: the pocket and springs.
    put the cam in lobes down with sprocket on and chain:
    Then aligned the T and O marks like said in manual:
ID:	178717Click image for larger version.
    put the gasket stuff on the cover:
    Put the cover on and finger tightened until the stuff just started to ooze out and am currently letting it set up for 1.5 hours:
ID:	178720Click image for larger version.
ID:	178721Click image for larger version.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    I think I found the problem as well:
ID:	178723Click image for larger version.
    The clearance is like 2.5 - 3mm. Don't know if the person that parted this out did this or what or if the previous owner had longer valves or something?? Anyways it's definitely not .05mm like it's supposed to be.
    So I'm thinking that's the reason it was so hard to turn over when the spark plug was in, the valves weren't opening enough.... I'll adjust them and put the plug in at about 9:15 and see it's any better.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    How long should I wait for the silicone to set up before I actually try to start the machine? Full 24 hours?
    Yes.... 3 bond or similar, just use a tad less and stay back off the journals per spec in the shop manual. Aftermarket cams need .002-.003 additional gap @ the rocker setting if it is not stock.
    Southern MN
    1,875
    I usually start it a couple hours after applying the sealant, but I use Hondabond, and it sets up fast. Be sure to get a feeler gauge, YOU NEED IT, you can pick one up at any auto parts store. They are made of thin metal, there are like 30 of them on one stick, all different thicknesses, select the right size, I believe its .003 inches both intake and exhaust, but check manual to be sure. Its a VERY small gap there, you'll never get it by eye. Its a little tricky the first couple times, but it will become easier after you do it a few times. You want there to be a slight drag on the feeler gauge, not too tight or loose. You have to adjust the gap by turning the square nut in or out, and the nut is to lock it tight. Turn the square part above the nut in with the feeler gauge in between, until there is slight drag when moving in and out. Hold the square nut in place, and carefully tighten the lock nut. Double check your work to make sure its right. If you don't have the special square wrench to hold the square part, use a needle nose pliers to hold it. This is the way I do it, as I do not have that tool, but this method works alright.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    The cam, valve/spring and rockers are all stock. I don't know why the tappets were so far out though. I don't have any feeler gauges, just going to do it by touch.
    haha, nvm, feeler gauge it is.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Yeah I have a smaller 10mm wrench and it will box on there enough to loosen/tighten. Are those feeler gauges super flimsy? So it can go over, vertically down and then between the tappet and valve? Or do I specifically need to find bent gauges?
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    It's .05 mm for this particular motor. At least that's what the book says.
    Mar 2011
    Red Lion pa
    1,542
    Feeler gauges will be "flimsy' on the smaller thicknesses. Think of this way, an average piece of paper is .004 -.005 thick. .05 mm is approx .002
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
  15. #30
    Southern MN
    1,875
    Yes, the gauges are flimsy, and able to bend just right. I was talking about inches, its 3 thousandths or .003in, I wasn't talking mm's. I live in the USA and use inches to measure, dosent the manual give an inches measurement, it usually gives both side by side? You could use a piece or regular notebook paper as a feeler gauge, it is .003in. Otherwise, just do it the right way and get the feeler gauge. Good luck, and let us know what happens!
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
