Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 68
Thread: 200s compression really high.
  1. #31
    MonkOFox's Avatar
    MonkOFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    texas
    264
    Oh yeah, .05 mm or .002 inches. I'm in the US too lol. I just called a buddy to see if he has a set.
    Oh, and I will keep you guys posted! Hopefully a video of me driving around tomorrow!
    1985 200S - fixer upper
  2. #32
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Ok im a dingaling i didnt have valve cover torqued down. When i tightened it down, there was much smaller gap. If i pull in the tappet though i can still here it tapping. Im going to check them anyway tomorrow once i get my feeler gauges. Would .001 of an inch make that much difference in difficulty of pulling the starter? On the up stroke, i can hear hissing. I guess that is the air going out the exhaust valve?
  3. #33
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    If i try to pull up hard, it seems like its just locking...
  4. #34
    Southern MN
    1,875
    Man it seems like you have something seriously wrong, unless your valve clearance is WAY too loose. Are you sure the timing chain is not damaged or binding? Check the clearance first, then go from there.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
  5. #35
    Sep 2011
    New Castle, PA
    1,134
    Quote Originally Posted by MonkOFox View Post
    I cleaned the valve... combustion chamber and the piston:
    Attachment 178709Attachment 178710
    Well, your piston isnt helping your problem any... The number on it corresponds to a 12:1 compression. stock is like 8.5 or 9:1. My X has a kick start and its tough to kick at 10.5:1... with a pull start, 12:1 will be HECK to start
    Gone:
  6. #36
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Crap.. Is the compression determined by the rings?
  7. #37
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    going to my buddies to get the old one.
  8. #38
    Sep 2011
    New Castle, PA
    1,134
    No. Look at the pic in the link below then read my explanation
    http://farm9.staticflickr.com/8241/8626261522_218de9095f.jpg
    The piston on the right (a high comp piston similar to yours) has a more "domed" top, and a larger piston top than a stock piston (on the left in the picture), as you can see, so it takes up more space in the combustion chamber and makes the fuel/air mix compress more, making a more powerful explosion. Yours is like the one on the right as well, and a 12:1 piston is the highest they make for the ATC's, and the 12:1 is meant for racing gas only, something like leaded 98 octane or above. thats why its heck to pull over, and if you want, a stock or 10.5:1 piston would be much better!
    Gone:
  9. #39
    I hate 12:1 !!!!!!
  10. #40
    Manitoba Canada
    95
    A high compression piston will make it harder to pull start, but if I were a bettin man I'd say you replacing the rocker cover is the problem. To test my theory I would suggest you slip the timing chain off the cam gear and try turning it back and forth with your fingers. It will NOT be able to go all the way around but it should move easily (in/out and back/fourth) I suspect the two halves do not match up PERFECTLY. As Honda recommends you replace both head and rocker box as a MACTHED SET.
  11. #41
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Damn, that's some sad news about the valve cover having to be the same... Lame. Well here is the old piston:
ID:	178728Click image for larger version.
    Another thing, this is strange to me. When you're timing, you put the T and then line up the sprocket with the 'O'. I was manually turning the crank and noticed this:
ID:	178730Click image for larger version.
    How does it end up 180 degrees off?
  12. #42
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Does it do two up and downs with one combustion or something? Another thing, the motor turns counter clockwise right?
    I googled 4 stroke engine and:
    "...The piston make two complete passes in the cylinder to complete one operating cycle ...". So that probably explains the O and T being
    180 degrees off in my previous post.
  13. #43
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Ok so, I have the motor parts back together with the old stock piston. Just have to get it in the frame and set up the stator/generator. Then I'll give it a pull and see if it's less difficult to turn over now. I pulled on the cam and it slid out (I had to turn it counter-clockwise slightly for it to come out). It may have been a little difficult because I adjusted the clearance closer just to see if that would make a difference (with the old piston in).
    Tore down the carb to clean it too. It had a thin layer of varnish in the bowl so I'm sure some of the jets are clogged. Been a sittin'. How do you drain a carb for sitting up a long period of time? Or is there no real way to prevent 'gunking'?
    I'll keep you guys updated! : ).
  14. #44
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Okay, got it back together with the old piston and pulling it was a breeze. Set the valves best I could (I think it was right). It's at a really weird angle, so I put the feeler underneath, let it hang and just snugged the tappet down until it wouldn't move then backed off until it would drag in between. Problem though, it's leaking like crazy. drip after drip and it's hissing between the cylinder head and jug. Not between the bottom end and jug though. I tried to snug the 8mm cap nuts on the cover more, but didn't really help. Guess I need to test the compression to make sure maybe there isn't too much?
    A little oil probably got on the gaskets when I re-tore it down. Is that a no no, or does it matter that much? I'm pretty comfortable putting it back together and stuff. Could timing being off make it leak like that? I put the 'T' on the flywheel and the 'O' on the sprocket lined up at the same time. Put everything on, then advanced the timing to the 'F' mark and put the stator/pulse generator on and then the CDI cover.
    It's idling high, but I can tinker with that. I'm just sad that it's leaking soo much oil : (. I'm using 93 octane gas, does that matter? Should I only use 87? Here is a video of it running:
    You can see a drip on the right side of the bike and later on you can see bubbling around that gasket. I can upload a better video if you want. Sounds like it's running good, just leaking like crazy for some reason.
    www.sportsmanstuff.com/1013131432.3gp
  15. #45
    Sep 2011
    New Castle, PA
    1,134
    Whenever I put my X together, the head leaked bad until I put the proper torque on all the head bolts. You will need a torque wrench, probably 1/2", and then torque the scorn nuts to 22 ft lbs and the socket head cap screws to 9 ft lbs. Just 'snugging' them wont do the job. They all need to be correct torqued and all even or else somethings going to go way wrong. Do it right the first time
    Gone:
