Hi chaps.
So I've bought a less than perfect recoil from Ebay. It has worked with less than perfect results so I've taken a peek inside. The dogs look newish, the rope pulley is decent. the cover has a couple of issues, as has the grabber on the flywheel, namely they both have elongated slots through wear & tear. That's problem no.1. Problem no.2 is I have a component completely missing - item 12 on the diagram;
So, am I ok to go ahead and add some weld to the slots and dremel them about to sort them out, and what does that spring (item 12) actually do please?
Actually, there's one more thing....
The dogs have managed to escape. I found them lying in the side casing under the flywheel. I've put that down to the long slots and they've be forced to pop out of their homes, is that a fair assumption?
Thanks again. Sorry for all the questions.
Cheers
Rob.
