Results 1 to 9 of 9
Thread: Time of year for cider.......in my tank that is.
    ericmreimer's Avatar
    ericmreimer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Splendora, TX
    296
    So my "parts bike" had a decent tank except the cap and inside was all rusted. So following the norm I went to a searchin'. Found a lot of people using apple cider vinegar to eat out the rust, I figured WTH, lets give it a try.
    I pored some small bolts and gravel into it and shook the heck out of it for about 5 minutes or so.
    Then used the shop vac to suck everything out.
    Then I pored in 3 gallons and its contently soaking. I set it on a board to put it on a incline. I think I'm going to let it go until tomorrow.
    I've already bought a NOS cap on line and new pet cock that are on their way. As soon as I get the the inside taken care of, its off to get painted. I'm having my buddy shoot it, put the new decals I just got on and them clear over the whole thing.
    Here are a ton of pictures of the before condition.
ID:	178846Click image for larger version.
ID:	178847Click image for larger version.
ID:	178848Click image for larger version.
ID:	178849Click image for larger version.
ID:	178850Click image for larger version.
ID:	178851Click image for larger version.
ID:	178852Click image for larger version.
ID:	178853Click image for larger version.
ID:	178854Click image for larger version.
ID:	178855Click image for larger version.
ID:	178865Click image for larger version.
ID:	178857Click image for larger version.
ID:	178866Click image for larger version.
ID:	178867Click image for larger version.
ID:	178868Click image for larger version.
ID:	178869Click image for larger version.
ID:	178870Click image for larger version.
ID:	178863Click image for larger version.
    Attached Thumbnails Attached Thumbnails IMG_6062.JPG   IMG_6064.JPG   IMG_6065.JPG   IMG_6066.JPG   IMG_6067.JPG   IMG_6068.JPG
    1984 Honda ATC200ES saved
    Project in progress 1984 ATC200ES with Trx200 rear suspension/200m front suspension
    May 2011
    eden,ny
    3,481
    and you have a gallon left for French fries!
    NO-SCALES's Avatar
    NO-SCALES is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2013
    DFW - TEXAS
    225
    Is it good for the caps too. I have 3 that will not let air in ,, might have to let one soak in some and see it helps
    85 Honda 250sx- STILL IN PIECES!!!
    84 Honda 185s - traded off
    85 Yamaha 225dr - parts machine for now
    83 Yamaha tri-zinger 60cc - my sons first 3wheeler. $300 for zinger, $4000 for a broken leg, memories for a life time - PRICELESS
    85 Honda Big Red 250es - traded off
    86 Honda 250r - traded off
    85 Kawasaki Tecate - new toy
    84 Honda 200m - super clean puttin around toy
    MN
    3,263
    It will do the job for sure on that tank! I have done a few now works great every time.
    As for the caps, sometimes, if you soak them upside down in a bucket of it for a few days they can sometimes free back up.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Jul 2013
    Splendora, TX
    296
    So this is where I'm at. clean tank but now I have a pin hole. So do you guys think this can be fixed?
ID:	178943Click image for larger version.
ID:	178944Click image for larger version.
ID:	178945Click image for larger version.
ID:	178946Click image for larger version.
ID:	178947Click image for larger version.
ID:	178948Click image for larger version.
ID:	178949Click image for larger version.
ID:	178950Click image for larger version.
ID:	178951Click image for larger version.
ID:	178952Click image for larger version.
ID:	178953Click image for larger version.
ID:	178954Click image for larger version.
ID:	178955Click image for larger version.
ID:	178956Click image for larger version.
ID:	178957Click image for larger version.
ID:	178958Click image for larger version.
ID:	178959Click image for larger version.
ID:	178960Click image for larger version.
ID:	178961Click image for larger version.
ID:	178962Click image for larger version.
ID:	178963Click image for larger version.
ID:	178964Click image for larger version.
ID:	178965Click image for larger version.
    Sep 2012
    Pompano Beach, FL
    56
    I've fixed small holes like that before. Since you are gettimg it painted I would go ahead and strip it and make sure there are no ther areas that may be ready to break thru. You can have a "good" welder fill the holes or cut those areas out and patch them with new metal.
    Current Rides:
    '85 ATC 250R (restomod in progress)
    '02 Suzuki GSXR 1000 (strecthed/turbo)
    '03 Honda CBR 954
    '04 Suzuki GSXR 600
    '84 ATC 200ES (Big Red)
    Previous Rides:
    '83 ATC 110
    '?? XL 125
    '85 ATC 125M
    '98 XR 200
    '02 Blaster (Trenga Racing Prepped)
    '91 Suzuki GSXR 1100 (stretched/turbo)
    North Dakota
    1,643
    Yup you could fix it! The welders out here at work and did an awesome job on his and he had a lot of holes! They just braced it back together!
    MN
    3,263
    I have fixed holes like that many times, but the best way to do it, in my opinion, is brazing not welding.
    Got any radiator shops around you? Those guys are usually the ones to take it to. They can braze it, check for leaks, etc. I got a shop here that i take stuff like that to, after he is done a little cleanup with the flap wheel on my grinder and a light sanding and then its ready for primer and paint.
    ^ I agree, I have braised pinholes and cracks before with success.
    That apple cider vinegar did a pretty damn good job! I bought some of that awhile back for my cats. Suppose to help allot of ailments.......
