Results 1 to 3 of 3
Thread: 200x piston in a 200s?
    Mr.Atc's Avatar
    Mr.Atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    gulliver,mi
    248
    Have the engine out of my 200s and im re doing the whole bike. Was wondering what piston to use to give me more power. Would a 200x piston work and make it have more power?
    MonkOFox's Avatar
    MonkOFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    texas
    264
    See what compression and size it is ( the x ). As long as it's 65mm you should be good as far as fit. All I've seen is 10.25:1 on ebay as far as bumping up. Not sure what the stock is 8 or 9 something to 1. Don't want to go too high, unless you plan on working out your pulling arm a lot.
    1985 200S - fixer upper
    6,810
    A 200x piston is a Direct fit and will bump you up to 9.2:1 on the compression
