I'll give you props, at least you brought video..consider shooting in the light next time!!
1/ "My electric start doesn't work. Batter is 100% charged, new battery, runs lights. Lights dim and solenoid just clicks when I press the start button. Took the solenoid off today and touched those two wires, pressed the button and nothing happens."
Either battery voltage is dropping under load (ie new battery) or the starter is pulling too much currect (ie bad starter)..we can't really answer which is the problem..
Maybe pull the starter and open it..pretty common for the brushes to go bad. A new set of brushes and a cleaning and you should be golden..
As for the battery, unless you have a load tester you're going on blind faith. Just because a battery charges doesn't mean its good..
2/ "Heres a video of my oil pump cover, it leaks even though its tight. Orings look to be good on the cover, do they still need to be replaced? or is it something else. The cover kinda doesn't sit flush in a few spots with the case. That the issue? (ticking sound is the rear bracket holding my muffler on vibrating NOT the motor)"
This should be easy to figure..take the oil filter cover off and replace the oring. While at it look it over for chips or gouges in the lip of the cap or filter socket..
3/ "Also, sound clip of it cutting out. Bit of stutter when you first hit the throttle and likes to cut out at anything past half throttle and spit flames. Backfires and pops WICKED loud. Carb is clean. Going to move needle and check fuel/air screw placement tom. Got a manual. If anyone else has had this problem/knows what it is let me know"
Mixture screw is definitely not your issue..that is the IDLE mixture adjustment. Once off idle it make no difference. Moving the needle from the factory position is rarely ever needed unless some change has been made to the engine or exhaust..so no need to go there.
Check valve adjustment, exhaust restriction or lack there of, you say the carb is clean..but is it FlyingW clean??
Suggest you go back to basics and hit the carb again..check and adjust your valves and secure your exhaust.
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
