Thread: 83 185s / 84 200m - parts swap???
    NO-SCALES's Avatar
    NO-SCALES is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2013
    DFW - TEXAS
    225
    I got the new mikuni carb installed last night on the 185($35 off ebay, shipped). runs like a champ. this thing has had a little bit of backfiring problem since I got it. looks like that has stopped with the new carb.
    now that this one is running right I was thinking I might be able to swap out the coil and cdi module from the 200m to test to see which one is bad on the 200m. looked on partzilla and part numbers are different , of course. anybody know if these parts will swap, from experience, or any reason i should not try to test them out on the 185?
    85 Honda 250sx- STILL IN PIECES!!!
    84 Honda 185s - traded off
    85 Yamaha 225dr - parts machine for now
    83 Yamaha tri-zinger 60cc - my sons first 3wheeler. $300 for zinger, $4000 for a broken leg, memories for a life time - PRICELESS
    85 Honda Big Red 250es - traded off
    86 Honda 250r - traded off
    85 Kawasaki Tecate - new toy
    84 Honda 200m - super clean puttin around toy
    Mar 2007
    Texas
    5,045
    If it is no longer backfiring, then most likley was a carb that needed a rebuild. the parts you can swap are the cylinder, piston, and head (but 185 and 200 same valves so no point there). you cna then get a 200x cap and a xr200 piston for a cheapo upgrade to 10:1 compression with your head. and better performance.
    good luck, has lots of funs!!!
    ________________
    https://www.mikesatvfix.com
    MN
    3,263
    Im not at my computer right now to double check, but i believe all the ignition parts should swap just fine between the 185 and 200. The 200ES used a round connector for the CDI but i believe the 200M used the square one like the 185. If the plug is the same it will swap just fine.
    Most of the stuff is swappable between them, a 185 is just a 200 with a slightly smaller cylinder size, thats it!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    NO-SCALES's Avatar
    Jun 2013
    DFW - TEXAS
    225
    Cool, thanks . Cdi modules do look similar, but didnt wsnt to fry anything,. Thanks
