Thread: Paddle tires for 250sx
    Dec 2012
    Newfoundland, Canada
    68
    Hey guys, winters just around the corner here and with all the snow we get i wouldnt mind having a set of paddle tires on the trike this year.. I'm not 100% sure on which tires/rims would fit my bike and which ones wouldnt.. would someone be able to send me a link to a set to fit an 85 sx? or does anyone know of someone on here with a set to sell? Thanks again.
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Buy yourself a set of Maxxis 4-Snow. Best winter tire ever and they are the same size as the stock sx tire.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Sarnia, Ontario, Canada
    3,415
    1st off the rim choice is pretty simple..any 4/110 Honda standard bolt pattern rims will fit. 8" diameter is stock for the SX, but a 9" or 10" would do if that is the tire diameter you find.
    The stock tires are 22x11x8, so you could use that as a safe starter size..22 or 23" diameter on the SX is a good area to be in..
    Now the other issue you will discover is a trikes design makes them very unfavourable in the snow because the front tire will tend to 'plow in' instead of floating over the snow..
    Our good friend Scootertrash is a member who has been playing around with that solution..he's fabbing a front ski using a snowmobile ski and making a mounting bracket whereby you remove the front wheel assy and install the ski kit!!
    One way or another I strongly suggest that a front ski is needed in addition to a pair of good snow tires for the rear!!
    Maybe even something like this..
    http://www.ebay.com/itm/ATV-Tires-to...0f0515&vxp=mtr
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Dec 2012
    68
    Quote Originally Posted by Yamada View Post
    Do you know the best place to order these from?
    King Trikester is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2013
    Canada, B.C, FSJ
    435
    Get a spare front axle and get someone to weld one up, I built one the other day for my 225dx, Im going to post a thread about it once its snows and i can test it out, any day now I can't wait
    Salt Lake City, Utah
    84
    ATC 350X-The Oem Piece
    ATC 500R-The Dune Hog
    ATC 70-The Cruzer
