Thread: atc 110
    Aug 2012
    Perth WA Australia
    120
    atc 110
    Hi guys im picking up this ATC 110 tomorrow, and was wondering if there's anything specific to look for that's potentially a problem source for these particular trikes.
    Also can anybody tell me what year it is, I thought it may be an 84.
    also any other details about these would be great, Just so I have a bit of knowledge before picking it up.
    Thanks a lot, cheers Mat
ID:	179544Click image for larger version.
    Cold Lake, Alberta, Canada
    3,016
    That looks as clean as they come. If it runs you've got it licked! All else can be fixed easily if there's problems. Rock the rear end from side to side to check the bearings, do the same with the front wheel. Is the exhaust rotted out? They sometimes break under the skid pan. Stiff or seized cables can be freed up or replaced as required. Rotten seat pans are hard to come by but I can only assume yours is fine. Not 100% sure of the year but my guess is 81 or 82. Let us know how you make out.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Mar 2013
    Central PA
    2,362
    Just give it a good once over just like any other machine. Aside from what coolpool said check the inside of the tank for rust, make sure it runs good, no smoke, all seals are not leaking, shifts fine. Normal checks you do with any bike.
    Aug 2012
    Perth WA Australia
    120
    Thanks very much for the your advice guys, i will pick it up today and let you no how it goes, cheers,
