Results 1 to 8 of 8
Thread: 81 honda 110 rings?
    Mar 2013
    hesperia
    68
    81 honda 110 rings?
    My 110 needs new rings but I don't know what size to get do I have to measure the bore? If so what do I need to mesure or could I just get one bigger then oem size they 52.00 all the way to 53.75mm
    MN
    3,263
    You really need to measure up the bore and see if its good enough for a new set of rings, chances are if your looking for rings she is smoking? If thats the case its probably time for a bore and hone and a new piston and rings.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Mar 2013
    hesperia
    68
    Yea smokes pretty bad has new valves and seal and adjusted right so my guess is it needs new rings but new piston also? If bore is still good can I just hone it and add new rings one size bigger? Can I do it my self or is it just better to go to shop ?
    MN
    3,263
    If the bore is still within spec you can hone it and then put in a new set of stock size rings, thats your only choice without having to bore it out, but you need a bore gauge and take some accurate measurements to see if its still within spec as shown in the service manual. If your not within spec then its time for a bore to a new size, then you need an oversize piston and rings for the new bore size. You can't just go up a size on the rings using a stock size piston hoping for a good seal. The cylinder wears out into an egg shape, the walls aren't square. When you bore it out you make everything square again and then because you went larger than stock you now need a larger piston and rings to match it.
    I would find a shop and have them do it, let them measure it and see if its ok to hone it instead, but i would guess if your blowing smoke its time for a full bore job.
    Mar 2013
    hesperia
    68
    Looking for big bore kit any1 know wer I could find one
    May 2013
    Brownsville, Tn.
    1,271
    Shortline.
    * Nicholson 500 Race Bike *
    Mar 2013
    hesperia
    68
    Huh,Shortline?
    MN
    3,263
    He is a member on here, Shortline10 if i remember right is his username.
