Thread: 84 250r hub help
    Oct 2012
    Somerset County PA
    720
    84 250r hub help
    I'm trying to get the axle out of my 250r gettin it ready for some work, and that dang hub just does not want to come off? I tried a lot of things with it to get it off, I have it soaking in pb blaster hoping that it will do the trick, if it doesn't work, does anyone know a way to get it off without ruining it?
    All help will be appriciated!
    Colton
    Quote Originally Posted by Howdy View Post
    Yea, looked like a monkey ******* a football. LMAO
    Howdy
    Currently Own-
    84 250R My Baby/Project
    83 Yamaha 225dx
    79 Honda Twinstar - Big Ole Turd
    Heres My Feedback Page
    http://www.3wheelerworld.com/showthr...for-ColtonGG33
    Nov 2010
    Oshawa, On, Canada
    2,123
    On my 86 when I bought it, I had to put the swingarm in a vice, heat the hub red hot with my oxy propane torch, and smack the axle with a block of wood and a 10 lb sledge. 50 hits later it finally came off. Of course since I heated the hub so much, it was garbage.
    I tried everything ( s, oil, heat, pullers, etc ), what i did was a last resort, but it worked and left my axle intact.
    Just make sure to not heat the axle red hot. I've had a few people mention that because of the heat, my axle strength has been jeopardized, but 2 years later, riding every weekend, jumping, climbing, smashing rocks. Still straight as an arrow
    I've heard of some people cutting theirs off, but I see most people damage their axle in the process.
    It was odd because the rest of the 86 is so clean, but the axle was in terrible shape.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Oct 2012
    Somerset County PA
    720
    i managed to get the other hub off pretty easy, a some heat and s and it came of as for the other one, i got it to move a little bit but i dont think its gonna come out, but with the hub i got off it should be fine for me to remove the axle to replace the bearings. thanx for the info jason!
    Howdy
    Currently Own-
    83 Yamaha 225dx
    Nov 2012
    Waldoboro, maine
    791
    Mattdragontamer had a neat trick he used for his Taurus resto, I think he soaked it in ATF and laquer thinner. Supposed to be the best penetrant ever. Don't forget to grease those splines before you put them back on to prevent it from happening in the future.
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Nov 2012
    Waldoboro, maine
    791
    http://www.3wheelerworld.com/showthr...-by-ODG-(Argo)
    Found it, 50/50 acetone and power steering fluid, he didn't think it helped much but hey, ya never know might be worth a shot.
    82 250r
    83 Big Red
    85 Auto-x
    Jun 2012
    Aberdeen WA USA
    139
    I've always used the heat beat and repeat method and I've never damaged a hub or axel I just take my time and don't get it too hot or hit it too hard. It just takes a lot of patience. and a heavy helps.
