Results 1 to 14 of 14
Thread: Carb help - es - sx
    NO-SCALES's Avatar
    NO-SCALES is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2013
    DFW - TEXAS
    225
    Carb help - es - sx
    I have a big red 250es that i got over the weekend, i noticed that the choke cable was broken off, it ran ,but kinda acted like carb needed a little help. I figured id just take the choke cable from the sx thats still getting work on, for the time being. 85sx , 85es ... I figured same year , same carb. If they are supposed to the same, someone changed one of them at some time, cause they are quite different. And of course the choke cable, and needle and do not fit. So i need to get one, and i need to know what carb i have so that i can order the right one. And not another one for the sx. The ones i seen on ebay kinda looked like the bigger one, that is in my sx carb. Someone please help me id these carbs, so i can get the right parts
    Attachment 179837Attachment 179838Attachment 179839Attachment 179840
    the one on the right , with the flat top is the one that came off the es.
    Also on the sx one , what is thet push , pull knob on the bottom??? And if it has a crack in the little rubber boot , will that let unwanted air in there or is just to shield off any dirt?
    Tried just swapping carbs , but the sx one needs help too, i make the exhaust really hot. Guess im going to see if i can send it to carb pro up in chocktaw, flyingw.
    If anyone has a complete choke, ( cable and needle ant plastic part that screws in the carb) laying around that they arent using, i would be interested , if not , off to ebay i go
    thanks for any help
    85 Honda 250sx- STILL IN PIECES!!!
    84 Honda 185s - traded off
    85 Yamaha 225dr - parts machine for now
    83 Yamaha tri-zinger 60cc - my sons first 3wheeler. $300 for zinger, $4000 for a broken leg, memories for a life time - PRICELESS
    85 Honda Big Red 250es - traded off
    86 Honda 250r - traded off
    85 Kawasaki Tecate - new toy
    84 Honda 200m - super clean puttin around toy
    NO-SCALES's Avatar
    Jun 2013
    DFW - TEXAS
    225
ID:	179845Click image for larger version.
ID:	179846Click image for larger version.
ID:	179847Click image for larger version.
    Nov 2007
    ulysses pa
    1,231
    Sarnia, Ontario, Canada
    3,415
    That left carb looks very much like the one on my 1990 TRX300FW quad..right one looks stock to the ES/SX, 86 is my guess judging by the extra vent hosing.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Aug 2013
    scotland uk
    69
    one on the right is whats on my 2x 86 250 es's
    NO-SCALES's Avatar
    Jun 2013
    DFW - TEXAS
    225
    Thanks trizilla... I had read that ,i did go back and reread though to see if i missed the part where i could tell these two apart. All i see iare pics that look the one on the right.
    I was thinking one might be an 85 and one an 86 or something, but now i guess i need to see if off a trx300fw now ,thanks for the help
    that could explain wht the different size choke holes, maybe
    so are all the choke holes the same size on the sx , es carbs? Or do they change with the year
    NO-SCALES's Avatar
    Jun 2013
    DFW - TEXAS
    225
    Acording to ebay piCs looks, the one on the left does look like a honda trx300 trx300fw 4x4 fourtrax carb ca32
    thanks. Looks like i need to get a new carb
    Jan 2011
    Choctaw, OK
    2,755
    In the first pic, I see its an 01A (85 ES) carb if my eyes are correct but it has the 86/87 vent hose configuration. The choke valve for ES/SX all years is interchangeable but the other carb is different as far as the choke valve goes.
    I have extra choke valves so if you want to send me your carbs for rebuild, I will return them rebuilt with a choke valve. You can call me anytime at 405.420.1114. Jim
    NO-SCALES's Avatar
    Jun 2013
    DFW - TEXAS
    225
    Im pretty sure thats what it says too. Hows it going to be an 85 with a 86-87 hose configuration? Isnt there different holes? Or did i make that up?
    3,415
    Then there is your other option..FlyingW carb fixes all your issues!!
    I have 4 machines with the 250cc power plant..I currently am running one of Jim's carbs and love it. He's rebuilding a second for my as we speak..
    Over the winter I'll likely get the other 2 done..then they will all run AWESOME!!
    Pack up your carb and it to him..then when the box shows up reinstall and fire it up!! No brainer!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    NO-SCALES's Avatar
    Jun 2013
    DFW - TEXAS
    225
    That is my plan, maybe he can make the trx one work for me. As soon as i get the extra cash, it is for sure going to jim
    Jan 2011
    Choctaw, OK
    2,755
    The TRX carb is not a good carb for the ES/SX. Different flow characteristics make it a bad candidate without having to completely rejet it. The 350X carb is a proven upgrade for the ES/SX motors but it too requires rejetting. The 350X carb is the same QA series carbs and it can be used with the stock choke cable configuration. I test the 350X carbs I rebuild on my SX. The vent hoses don't matter. When I rebuild my carbs, I setup the vent hoses in the 85 configuration i.e. 2 simple hoses rather than that spaghetti mess the 86/87 carbs came with.
    3,415
    Quote Originally Posted by Flyingw View Post
    I'm interested in this 350X carb upgrade..how is the power improvement??
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Jan 2011
    Choctaw, OK
    2,755
    Marginal in my opinion but then again, I've never committed a 350X carb long term. I will do this in the next week and report back.
