Results 1 to 15 of 24
Thread: weird dg pipe question?
    fallguy666 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2013
    athens jawga
    201
    I bought a full DG system this morning for $40!!!! Went to meet the guy a 6:30 this morning.got the pipe and through it in the bed of my truck without really y looking at it(knew it had to be better than what I was running.lol) got home,slept for a few hours got up and came to work.started wrenching on the 350x got the stock pipe crap off and went to install the new header,got it on with no problems.got the muffler and went to put it on a noticed a supertrapp disc pack on the end!!! Its got four disc in it and looks like it was made for this pipe? Has anyone seen this before?
    North Dakota
    1,643
    Yup I just bought a pipe that had the same setup. Took it off it blew a seal at the beginning section of the pipe due to, to much back pressure frim that disk set up.
    Aug 2013
    athens jawga
    201
    Yeah,I took the all the disc out cause it sounded like crap and way to much back pressure.killed my top end.is this something super trap made for the DG or is it just something that works?
    North Dakota
    1,643
    I believe it's just something that just works lol!
    Jan 2013
    minnesota
    5,911
    that is a std ole super trap. they were around in the early 70's. the more discs you add the LESS "back pressure" it has.
    Jan 2013
    minnesota
    5,911
    you can buy the discs separate.
    Jan 2011
    VA Baby
    225
    Quote Originally Posted by fallguy666 View Post
    Taking the disks out adds back-pressure & makes the exhaust quieter... at least that.s how the supertrapps work... the more disks your add, the more free flowing & loud the exhaust will be... I think on supertapps you can add up (12) disks.. I think...
    Safety 3rd
    6,808
    I thought they were added as a spark arrestor
    Aug 2013
    athens jawga
    201
    Quote Originally Posted by LastFoolerInVA View Post
    um....I don't know about that.I took all the disc's out and all there is left is a big hole.I'm pretty sure it was added for the spark arrestor
    C.J is offline Just Too Addicted Arm chair racerJust too addicted
    Central, Louisiana
    639
    The more disks you add, the less back pressure, more free flowing, and more of a "top end" pipe it becomes. The less plates, the quieter, bore back pressure, and more "low end" pipe it is.
    http://youtu.be/R3_AfJjjfrU
    On this DG pipe it's probably just something that works so someone could get around the spark arrestor laws
    too many bikes to count. too little time on hand.
    Aug 2013
    athens jawga
    201
    Yeah the guy I bought it from was from Florida. I understand about the disc's, I just took em out as to not have any back pressure. for some reason my 350 didn't like being stopped up like that.
    North Dakota
    1,643
    The one I bought had blown the seam out right as it starts to cone bigger. Here is what this one looks like.Click image for larger version.
    Central, Louisiana
    639
    So you're running with no end cap as well?
    Aug 2013
    athens jawga
    201
    Nope.lol.just a big hole.now the inside of this pipe doesn't look at all like my buddys DG.its the same system
    North Dakota
    1,643
    I took my disks and everything off also. No reason for super trap disks on it. I know they don't belong because the bolt has been cut down to fit correctly.
