Results 1 to 14 of 14
Thread: 350x vs 250r questions
    Oct 2008
    Reedsport Oregon
    856
    question:
    my buddys and i all ride dunes
    we all ride 200x's 83-85's
    everybody wants a 350x for more power
    i just picked up a first gen 250r and they think a 350x will keep up, i just dont believe it!
    i had a stock blaster along time ago (it did have lrd jets and needle though) and i raced a 350x, the x barely beat my blaster!
    the 350x's go for alot of money out here, while older R's are cheap
    any input?
    Sarnia, Ontario, Canada
    3,415
    Since the 250 has a 2 stroke power plant specifically designed and built for racing it's gonna be the hands down favourite in a X vs R race.
    The torque if the 2stroke is a without question a big advantage over the heavier though larger displacement 350X.
    However, in my opinion where the 350X wins is the even power curve..I can cruise this relatively tame animal and ride with my family all day. But when I'm feeling like busting loose the 350X doesn't hold back and can kick up a lot of dust!!
    The 4 stroke also gets much more running time on a tank of full and generally speaking requires less repairs and maintenance than the racing power plant which tends to need rebuilding much more frequently!
    For me the 350X is a more versatile ride, and on a challenging day can still keep time with guys on the Rs!
    If you can luck out and find a decent 350X for a good price add it to you collection..they are harder to find than the Rs because they weren't produced for as many years and in as high numbers.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Soutwestern PA
    2,040
    A 350X compares pretty favorably to an air cooled 250R. I can't say which is faster, it depends on the particular trike (tires, gearing, mods), but they are fairly evenly matched in stock form. Obviously, the power delivery is very different, but a 350X with a skilled rider can keep pace with an air R.
    Keep in mind, we are talking about 1st and 2nd generation R's......... a liquid cooled 85-86 250R, is a very different animal.
    Jan 2011
    VA Baby
    225
    my brother's 86 350x vs my 84 250r (air cooled)... the R would take the X every time till top speed came into the picture... with a 6 speed tranny, the x just has a higher top speed... I bumped my r up to a 14 tooth front sprocket (stock is 13) & was able to keep up (but also lost some speed on the take off, so the races were neck & neck) ... until we finally raced down the pavement.... wide ass open for about 2 miles (maybe 3)... I could def. keep up with the x... but... I ended up melting the piston rings... and the x just kept on cruising down the road...
    Safety 3rd
    devore,ca
    1,042
    Drag racing, the 1st gen R. Just about everything else, the X.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Tionesta, PA
    5,747
    Quote Originally Posted by LastFoolerInVA View Post
    The six speed is not like another gear - it's just the 5 of the R are further spaced out and the 6 of the X are closer together. I hear this a lot and it drives me bonkers.
    Oct 2008
    Reedsport Oregon
    856
    i like jumping more than anything and i hear a 350x has a weak frame?
    i know a 350 is heavy, the old R is very light! that makes a huge difference jumping
    in this case its been take what you can afford, and 350x's dont come cheap!
    Nov 2010
    Oshawa, On, Canada
    2,123
    I jump my 85X regularly on my ice track. ( yes, ice track with snow jumps ) holds up fine.
    But then again i'm only 170 lbs.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Sep 2011
    New Castle, PA
    1,134
    if you're worried about a weak frame, just get a TPC gusset kit (as long as you have good MIG skills). never look back
    Gone:
    May 2013
    Henderson, Tx.
    977
    I just finished installing (last night actually) a TPC gusset kit on my 86 X. Very good kit, just need to be able to weld. Not that hard, really.
    Nov 2004
    Waterloo IL
    2,701
    My 84 250R with fresh Wiseco, full exhaust and Boysen reeds will beat my 350X with 10.5 Wiseco in a drag but I like the 350 more.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    devore,ca
    1,042
    If you get an '85 x it's most likely that the frame is already cracked and needs repair, or has been cracked and fixed already. If I were into jumping, the x would not be my first choice. The x is a PIG of a trike.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Soutwestern PA
    2,040
    Lots of good feedback here. Did they answer your question, Hawaiirider? Or rather, verify that you made the right decision.
    Sounds like the air cooled R is a good option for your riding style and for your wallet.
    Blossvale NY
    4,563
    As much as I would like to add a 1st and 2nd gen R to my stable, given the choice between a 1st gen R and a 350x, I believe I would go with the X...
    But being you ride dunes, the main advantages the X has over the early R (mainly suspension) may be nill.....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
