Results 1 to 3 of 3
Thread: yamaha TRI Z 86 TIMING
    Mar 2013
    liverpool england
    33
    Gents what is the correct timing for a 86 tri z, i only have a manuel for a 85,it says 1.66 btdc is this correct?,and would it be any different if the bike is not standard, mine has full d+g and 38mm keihin carb,thanks
    TRI Z 85 SOLD 95-96
    TRIZ 86 2013-KEEPER
    May 2013
    Quebec, Canada
    134
    1.27 +/- 0.1mm BTDC http://www.3wheelerworld.com/oldsite...ls/YTZ250S.PDF you might need to download this PDF to view it, go to last page (service data)
    18degrees BTDC at 2000RPM http://www.3wheelerworld.com/showthr...Z-Service-Data
    I don't know if this info is all correct there is something weird in the PDF file, in the same section (service data) it says spark plug NGK B9ES and the first page (cylinder head parts list & diagram) NGK B8ES
    Mar 2013
    liverpool england
    33
    Thanks Dave I had it set at 1.66 it just didn't seem right today, ill re set tomorrow, on the plugs side they both do work but I think the No9 just runs hotter
    TRI Z 85 SOLD 95-96
    TRIZ 86 2013-KEEPER
