Results 1 to 9 of 9
Thread: 85 250r rear bearing help
    Auto_Demon's Avatar
    Auto_Demon is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Stonewall, Manitoba
    290
    Question 85 250r rear bearing help
    So im trying to replace the rear axle bearings but the old ones arent coming out, ive got most of the bearing out but the outside track, ive done everything short of cutting it, does anyone know how to replace these properly? Any advice is greatly appreciated
    1985 Honda ATC 310R
    "Man your 4 wheeler must be fast, cuz you were haulin' ass, when I passed you on 3 wheels"
    Jan 2011
    Choctaw, OK
    2,755
    Heat Baby!!!!! The aluminum carrier will expand faster then the steel the race is made of.
    Jan 2011
    Choctaw, OK
    2,755
    It also helps if you have a long drift and a to get the races out. Now for the installation, heat the carrier to about 200deg and freeze the bearings over night. Be sure the inside of the carrier is smooth prior to installing the bearings.
    Auto_Demon's Avatar
    Stonewall, Manitoba
    290
    Couldnt i just use a shop press as well to get the new ones in?
    1985 Honda ATC 310R
    Jan 2011
    Choctaw, OK
    2,755
    absolutely. its pounding on the bearing I discourage so yes a press is one good option.
    Nov 2010
    Oshawa, On, Canada
    2,123
    I use a length of 3/8 threaded rod as a press for my carrier bearings. Washer the size of the bearing and a nut on one end.
    Bigger washer the size of the carrier edge on the other end. Tighten it down, presses it in.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Heat it and slam the carrier on a 2x6, they will drop right out!!
    Jackson MI
    1,688
    It's hard to find a sharp edge to butt any kind of punch against if it's the outer race. In the past I have tack welded a small piece of round stock or flat stock from one side to the other of the race just for something to tap on. Be Very careful not to to hard on one side (especially the brake stay side) as it can cock the race sideways and split the aluminum as it's thin on that side. Be careful heating aluminum!!!!! A lot of people learn the hard way when heating it as all the sudden with NO notice it will melt into a big Blob.. Aluminum does not turn red like steel, it just drips off onto the floor and is then JUNK..
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Yes, propane only. No oxy/acet
    Aluminum is just like butter in a microwave!!
