I am working on 85 klt 110, I have cleaned carb out, change plug, put on a new flywheel old on was shot. It seems a little better with the new flywheel, I will have to check the timing not sure if it's a issue. Start's right up idles fine, when in neutral you can rev it up no misfires. when riding low throttle fine, get on it and it break's up fall's out flat almost like stalling but does not. definitely does not like hills compression is 150. no leak's in engine. not burning oil. checked most wire connections look good. spark is strong. Could this be a valve problem, cam, chain ,n ot sure how to check these. I have only work on four strokes. so any help would be appreciated. I will check carb float adjustment again to verify it. I aslo have clippped spark plug wire back at the end to ensure good connection.
