Results 1 to 15 of 16
Thread: A Few questions
    Nov 2013
    Chula Vista ca usa
    29
    A Few questions
    New to the forum. Glad I joined. I have a few questions about my trike. It's an 85 250R looks to me that it has a custom pipe. Now the trike is set up for drag it has an 8" extended swing arm (from what I was told its 8") previous owner had taken all the lights off I believe the wiring is all there I eventually want to get all lights put back on so I hope that they are the correct wires.I paid $800 for the 250R it runs but has some minor wear and tear issues shock seals and such. It fires right up first or second kick. Now here are my questions.
    What ratio should I mix the gas and pre mix oil ?
    How hard would it be to get the bike back to where It will be a nice duner with some good power.
ID:	180286Click image for larger version.
ID:	180287Click image for larger version.
ID:	180288Click image for larger version.
ID:	180289Click image for larger version.
ID:	180290Click image for larger version.
ID:	180291Click image for larger version.
ID:	180292Click image for larger version.
ID:	180293Click image for larger version.
ID:	180283Click image for larger version.
ID:	180284Click image for larger version.
    Blossvale NY
    4,563
    First of all, welcome aboard!
    Secondly, you did great for what you paid by the looks of the pics.
    Once you get through the new member probationary period of 2 months and 10 posts you should be able to score many of the parts you need like the headlight and tail light right here in the classifieds section of this forum.
    I am not sure who makes that pipe. I can identify a few of the ATC pipes but not all. And yours I do not know what it is, but it looks like it might be a nice one beside the dent.
    I would at least run a quick compression test to give you a rough idea of the condition of the top end. A stock engine should be around 190psi if it is fresh. Also, a compression test can be helpful in determining what type of fuel to run, whether it requires race fuel or pump fuel.
    I don't ride dunes, so I am not sure of the nuance things duners typically do to make their rides do what they want in the big sand.
    As to fuel and oil. That is a very well covered and debated topic. After much reading and researching for myself, I have settled on running castor based oil (Maxima 927) at a ratio of 32:1. Do your own searching and researching and make an informed decision for your own reasons based on your particular situation. Every R owner isn't in the same exact situation
    Congrats on an awesome score! Around where I live you would be lucky to find an air cooled R in somewhat rough shape for what you paid for that '85!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Nov 2013
    Chula Vista ca usa
    29
    Thank you for your response. ya I am super stoked on my score. I have always wanted a 85 250r and now my dreams have come true. I talked the guy down almost $800 from his asking price I will definitely get the compression check done. I have to rebuild the carb as we'll the previous owner didn't clean the bike after he used it so there is sand everywhere when I first started the trike I was surprised this thing sounds like a beast I can't wait to own some quads out at the sand drags this season !!!
    Nov 2013
    Chula Vista ca usa
    29
    So when I do a compression test do u hold throttle open or keep closed? How many Times should I kick the bike or just kick until gauge doesn't move anymore? Should I leave the gauge pressurized for a couple minutes to see if it Holds?
    Apr 2010
    Indian Falls, NY
    1,289
    No need to hold the throttle open. You're flooding the engine and wasting fuel. Couple times should give you a good reading but you don't really need to do it more than once.
    Nov 2013
    Chula Vista ca usa
    29
    Quote Originally Posted by slashfan7964 View Post
    Ok thank you I'll give it a shot
    Blossvale NY
    4,563
    I have always held the throttle wide open to allow the most air into the engine for a compression test. Kick it till the gauge stops climbing.
    There are differing opinions on this though
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Nov 2010
    Oshawa, On, Canada
    2,123
    x2 on throttle wide open. You will have a lower reading with the throttle closed. Its not like you will miss the 2 cents of fuel 10 kicks will use... lol
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Nov 2013
    Chula Vista ca usa
    29
    Quote Originally Posted by Jason125m View Post
    I kind of figured it should be open. I hold it open when I check compression on my stand up jet skis.
    Nov 2013
    Chula Vista ca usa
    29
    http://m.youtube.com/watch?v=YWI1FeIRS5w
    Here's a little video I took earlier of her fired up and idling
    Nov 2013
    brawley, CA, imperial county
    125
    Nice looking 250, that swing arm is way longer than I thought, it looks great for drags but that much extension will bottom out on razor backs when dunning. I live in brawley which is 30 min. from glamis so I go out almost every weekend. I looked around and saw a +4 is great for dunning and drag racing but yours looks badass chromed out.
    Nov 2013
    Chula Vista ca usa
    29
    I got the bike cheap. I couldn't pass it up. I'm a duner through and through but I do love the straight speed. Maybe I'll just turn it into a hill / sand dragger. Gotta look into getting the lights but low on fundage at the moment
    Mar 2013
    Baldwin, Wi
    603
    Great buy. looks like a Dynoport pipe. There are companies that can fix the dents if your concerned.
    85 Tri-z Basket Case
    Nov 2013
    Chula Vista ca usa
    29
    Quote Originally Posted by NeverLift View Post
    Will the dents mess with the performance any ?
    Nov 2013
    125
    Not really but if your looking to get every ounce of performance out of it with no flaws then you should get it fixed but it will have to be re-chromed. Any metal shop can take care of that for you
