Results 1 to 15 of 24
Thread: swapping to a 2-smoker kx65 motor
    Mar 2007
    Texas
    5,045
    well as some of you know my son has been racing ATVs for the last 4 years now. he competed in the 70cc class at the TQRA Pro challenge last month. I actually dropped in the baddest engine we have build for his class yet. (114cc allowed) we were making upwards of 15hp. went from a 42T rear to a 34T rear and front from a 13t to a 14T. we should have been smoking it! well nope... on the back straights he had it pinned in 4th gear and them dam CVT 2-smokers passed him by like he was walking. So after asking around we decided to get a kx65 and swap the motor into it. So that is the next project. I'll post photos and stuff as we go. But ummm yea... int he small CC class a 4-stroker just cannot compete.. Let alone with a hopped up 70cc 2-stroker. that is pretty much like running a tweaked out 200cc 4-stroke air engine.
    ________________
    https://www.mikesatvfix.com
    Buffalo, NY
    1,996
    At all the races i was at this year it seemed like there were a couple kids per class that were running bike motors with manual clutches. I also noticed that these kids were always near the back. Id bite the bullet and run one of those cvt motors
    Mar 2007
    Texas
    5,045
    we re going to use a recluse semi-auto clutch conversion for the engine so no manual clutch. rules do not allow for manual clutch. usually the ones in the back are learning to ride. my son has been racing a while and knows how to shift gears. the problem is an engine that can compete now. I had thought about that, but the cost of swapping to a DRR or apex then trying to make it competitive is so high, it's crazy. I know guys with over $6k into an engine assembly. not me.... he's not a grad champ racer. he's ok and decent but now grand national one. so for me to fork over more $ in an engine than I spend all season is beyond my ability right now.
    ________________
    Buffalo, NY
    1,996
    Ouch, i can see why youre going with the 65. I didnt know they make a rekluse for those, thats pretty awesome. I dont know what your max cc is but eric gorr has a kx65 big bore that puts it up to 72cc. Here s the link http://www.eric-gorr.com/bbmasterlist.php I havent bought anything from him so i cant give a review but i am planning on buying a big bore for a kx100 this winter from him.
    Mar 2007
    Texas
    5,045
    cool man, thanks!
    we are limited to 114cc 4-stroke or 70cc 2-stroke. no manual clutches allowed. stupid rule on the clutch...
    ________________
    Mar 2007
    Texas
    5,045
    got the kx65 and will soon be working on mounting it to the atv frame. i am planning on running a yfz450 radiator as it is larger and should work easier for atv use.
    ________________
    Mar 2007
    Texas
    5,045
    updates:
    I talked to the racing guys, they said we would only be able to run the mini-open. the good thing is that allows for up to a 104cc 2-smoker and does let you run manual clutching. so we so not need the recluse clutch now! $$ saved!
    I got the old engine out, cut the old engine mounts out and even removed and patched the frame where it had been factory notched for the 4stroke. I put in a full tube there and welded it up so no more notch or dip. much stronger!
    now, I mounted the kx65 motor, welded in now engine mounts and even put in pipe mounts too. I installed the rear swinger and put the chain on and spun it over by hand looking for chain bind. none to be found! fits like a glove!!! I have not had time to get pics up, but I will when I'm done. this is turning into a nice project! I think it is really going to pay off too!
    ________________
    Buffalo, NY
    1,996
    Get a kx100 motor if you're allowed that much more displacement. I have a yfz radiator but i dont know when ill be able to get to it. If you can wait a little bit maybe we can work something out.
    Mar 2007
    Texas
    5,045
    thanks man. I made some mods to the bike frame. I am now able to stuff a 7" tall radiator behind the bumper where before I could not. width is not a factor it was height between the bumper supports where it mounts to the frame.
    the problem was last year's rules let us run in the 70class but this yr they made some changes that forced us into a different class. sucks, cause I already purchased the bike and tore the engine out and sold the rest of the bike when i found out. so i am sorta stuck. So in order to help, we will drop in an Athena 82cc BB kit. That will probably be the best bet we can do at this point. 82cc with 12.5:1 compression is still a decent setup. plus this is a 6speed. unlike the CVT bikes that eat up performance when converting power through the CVT setup. so in the end, he will actually come out pretty close to the CVT rear wheel power, but with 1 advantage. His engine will have a faster top end in 6th gear.
    ________________
    Buffalo, NY
    1,996
    Sounds like it going to be a potent combo, can't wait to see some pics. Are you on facebook? There is a guy in the northeast selling a Nacs kx80 race quad from the 80s, its posted in the tecate group. Its pretty neat, dont know if youd be interested but it may give you some ideas.
    Mar 2007
    Texas
    5,045
    ok here you guys go, pics!!!!!
    this is a 155Z that was built to a 180cc. I actually have a typhoon I picked up for me and I will drop this into it so I can chase little man around torturing him on the track to make him go faster.
    This is the old 125cc that made close to 17hp. fully built stroked, and all custom work done. has 15:1 compression
    here you can see I chopped away all the old mounts and installed the new kx65 with new mounts into the chassis.
    another engine photo in chassis. (close up of mounts)
    assembled in quad. fits nice!
    here you see everything fitted perfectly! fit like it came that way!
    another angle of fitment.
    ________________
    Mar 2007
    Texas
    5,045
    engine updates:
    today I torn into it and rebuilt it. I installed all new seals and bearings. I installed a new hotrods crank so it is stronger and better balanced than factory for better RPMs. I upgraded the old stocker to a tusk performance clutch.
    the engine will be sent off next week to a pale that will punch it to a 85cc and machine and custom mod the ports. it should run as fast as a 100cc when completed!
    I still have to buy a pwk 28mm carb and some other odds and ends, but it is getting there.
    I will post photos as I go.
    ________________
    Dec 2012
    Austin, Texas
    50
    What kind of quad is that? Looks good.
    Buffalo, NY
    1,996
    Your son is a very lucky kid, good job. I would love to take that for a spin, meet at trikefest? Lol
    LT80 is offline New to the board Arm chair racerNew to the board
    East Springfield, PA
    64
    "went from a 42T rear to a 34T rear and front from a 13t to a 14T. we should have been smoking it! well nope"
    Did you ever figure out why this gearing combo was slow?
