Results 1 to 15 of 16
Thread: extended swingarm ????
    fallguy666 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2013
    athens jawga
    201
    Would a 4" over swingarm make a 350x slower or feel like it tops out to quick? The reason I ask is because me a my buddy have identical '86 350x's and mine will smoke him.when we drag race he gets me off the line but I pull on him(hard) and pass him by third gear? Same exhaust(DG)same air filter,same jets.mine has a new top end but his has a nos motor.when we got his motor it still had the motor mounts bolted to it where they cut it out of the frame.my compression is 198,his is 176.I'm lost on this one as the only difference is the swinger?
    Aug 2013
    athens jawga
    201
    Oh yeah,both have new stock sprockets and chains
    Southern MN
    1,875
    The length of the swingarm will have no effect on speed in a straight line. Do they both have the same tires? If so you guys should trade bikes and drag. Its probly more operator error, or a poorly adjusted/jetted machine. If you beat him on his, he is a slouch when it comes to drag racing.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Aug 2013
    athens jawga
    201
    Tried changing rides.same outcome.as far as jetting,they are both identical and the numerous plug chops say they are both spot on.I'm really confused on this one.his just feels like it runs out of gear sooner and quicker than mine? Both run a 13/40 setup
    Aug 2013
    athens jawga
    201
    As for tires,his are old school turf tamers and mine are brand new bazooka's ( hole shot knock offs) both in 20-11-9
    Southern MN
    1,875
    Maybe his bike is spinning due to not enough traction, or his clutch may be slipping. There are a number of factors it could be. You should have put this in the this vs that section of the forum.
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Aug 2013
    athens jawga
    201
    Um,no.its not a vs thread.lol.its a tech question.as far as spinning,no.he just flat takes off.the clutch is perfect.I would have felt it when I raced his.I'm stumped
    Blossvale NY
    4,563
    Valve adjustments??
    Yours might be spot on and his may be due for an adjustment. Improper valve lash can have a significant effect on performance.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Aug 2013
    athens jawga
    201
    This could be the answer!!!! I checked the valves on his motor bout 8 months ago and they were perfect.it might have twelve hours on it since then,hard hours drag racing and wheelies.I will check and report back
    Aug 2013
    athens jawga
    201
    He paid around $1800 for the motor less than a year ago.it was in an aqaintinces dealership for 20 something years
    Aug 2007
    Montana
    857
    Quote Originally Posted by fallguy666 View Post
    The difference is in the tires! even though they say 20x11-9 the diameter of the tires are different! I battle tire size all the time! Ol Deuce
    DO the Best With What you got !
    My Feed back :cool
    Aug 2013
    athens jawga
    201
    We thought about that.we are within half an inch of each other.it even did this with my old wore out tires?
    Mar 2013
    Baldwin, Wi
    603
    22 PSI lower than you motor translates to less HP add on the extra rotating mass of 8-10 inches of chain and that's slowing him down too. Have you ever weighed his tire/wheel combo compared to yours? I bet yours are lighter.
    85 Tri-z Basket Case
    Aug 2013
    athens jawga
    201
    The difference could only be marginal.also I am 35#'s heavier than he is? We actually had my wife race me on his just to see.same outcome and she is only a buck ten
    NEPA
    7,051
    Do you know how much machine work thousands of guys over the years have done to GAIN 22 Lbs of compression lol!!!! Assuming all bearings and rotating mass/drag are the same. The compression and tires are the difference.
