Hello, I'm new here and my main reason for joining is that I recently bought a 83 Tri-Moto 200 (YTM200EK) and I'm having a big problem in getting it running.
When I bought it, the seller claimed it runs, said the battery had been dead for some time so he would always just jump start it off his truck to get it started; when I went to see it before buying it he had the jumper cables hooked up to it but the throttle cable broke and he couldn't get it started. Despite that I ended up buying it, he was asking $400 and I ended up paying $200 for it. All the plastic it good and other than lots of mud on it, it's looks good.
Well now after a couple weeks, I have ordered and recieved a few parts for it, a new throttle cable, carb needle valve (carb was leaking fuel from it's overfill port), a carb bowel gasket and few other things such a oil filter brake pads, etc... Also put a new battery in it.
Now I got the throttle cable installed, replaced the needle valve and seat, adjusted the pilot screw per the Haynes/Clymer service manual I found online yet I can't get it running yet. The best I have gotten is a slight fire and a brief second perhaps two idle.
I have experience in small engines esp garden tractor type but limited ATV/ATC motorcycle stuff but I have done basic stuff like change/gap spark plug, dumped the gas out and replaced with fresh fuel, also I have taken the carb apart and cleaned everything including running wire through all the brass port jets making sure nothing is blocked and sprayed carb cleaner though everything then reassembled it all.
Can anyone offer suggestions of what to do next or what I might check next? I have a spark tester so I checked that and it has a good spark. This Yamaha has a Mikuni VM22SH carb, I have searched all over the internet in search for technical support of such and found some info, mostly jets kits for high performance racing and tuning but nothing really as far a basic help.
In taking the carb apart, there wasn't a lot of crud or deposits so it's not like I'm working with a basket case so is there anyone out there with any ideas? It doesn't seem it should be this hard to at least get this trike running!
Thank you in advance!
