Must be something in your tire sizing since the 85-87 SX has the same ratios in the transmission and rear differential. Size tire size changes final drive ratio its one suspect..and don't say they are both 22x11x8. Since no two manufacturers can build a tire of the same size..even though they are listed as the same size..
Suggest you use a fabric tape and measure the outside diameter of the tires on both machines and see how much different they are.
Also your 87 had it's differential replaced with one from a 250ES at one time..that would also cause your concern since the ES differential has a higher ratio differential than the SX to compensate for it's bigger tires.
Could also be a clutch slipping!!
Needs further investigation!
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
