Thread: 200x won't run long
    averysdad is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2013
    Cleveland, tx
    218
    200x won't run long
    1984 200x cranks but only runs for a couple minutes then acts like its running out of gas but it is getting gas. This started after popping wheelies then dies will start but won't run long.
    Apr 2006
    SE CA Dez in the sandbox
    900
    Float stuck? Fuel Filter? Something in the gas tank moving around over the outlet?
    London, Ontario, Canada
    1,059
    Gas tank vent may also be plugged, see if it runs with the gas cap off.
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    Jan 2013
    Cleveland, tx
    218
    I have cheeked all that stuff. Took the drain screw out of the carb bowl and left the gas on gas pours out. Idk maybe clogged jets? But I just cleaned the carb not to long ago
    Slidell, LA
    4,738
    Jets are clogged, float may be damaged/improperly set or could be some severe air leaks.
    Cornholio's Avatar
    Cornholio is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Staples Minnesota
    180
    Splash shield in the carb? CDI box?
    Life is short, Party naked!
    1986 250r
    1984 200s
    1984 250r
    1970 us90
    1991 Yamaha Blaster
    1984 110
    1985 110
    1984 200x
