Results 1 to 8 of 8
Thread: gas comming out of air box after valve adjustment
    Sep 2013
    ionia michigan
    6
    so i just adjusted my valves on my honda 185s atc i had to take the carb off to get to the intake valve and i let it sit overnight because it got late next morning i did the adjustment and put it back together fired it up and noticed that intake valve was way lose also that gas was comming outta the air box drain figured it was just intake valve being off so i readjusted the valve and tried to fire it again and then again gas was comming outta the air box drain so i have given up for the night and decided to post here for help any input would be greatly appreciated thanks
    Jan 2013
    minnesota
    5,911
    maybe your carb float got stuck. try shaking it or remove bowl and check it.
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    So if your valves are adjusted right I would say when you pulled the carb off the float stuck open... Has the carb been cleaned?
    MNhondaguy's Avatar
    MNhondaguy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2013
    fergus falls, mn
    203
    Tap the bowl with a screwdriver handle, that usually does the trick for a sticky needle.
    Sep 2013
    ionia michigan
    6
    yes i cleaned it a couple weeks before i adjusted the valves poorly tho
    Pacific NW
    4,255
    I shouldn't say this but after a carb fix, I've been known to put a few drops of 2 stroke oil in a piece of clear fuel line and mouth blow it into the carb with the float bowl drain open so it blow past the float needle and seat.
    I also blow into the carb and turn it upside down to make sure the float moves ok (shut off and opens) before I put it back on.
    Pretty sure I'm gonna try that with one I cleaned recently that decided to start leaking for no good reason.
    Last one apart seemed to have some sort of dark plasticky varnish surrounding the needle so it was aclohol and Q tip to the rescue.
    Amazing that this technology was commonly used to fly planes across oceans.
    May 2009
    S.E. Michigan
    1,251
    Is the gas coming out of the float bowl drain tube, or out of the airbox drain tube? You said airbox above, but I just wanted you to restate it because everyone is talking about gas leaking due to a stuck needle.
    If it is truly leaking from the airbox drain hose, then gas is getting blown back through the carb throat and into the airbox, which to me says you messed up your valve adjustment. If the intake is hanging open a bit, it is going to shoot back some air/fuel on the compression stroke back into the airbox.
    Take another look at your valve adjustment and make sure you had the piston on the compression stroke when you adjsted the valves.
    Remember, your flywheel will go around past the timing mark twice: once on the compression stroke and once on the exhuast stroke. You need to make sure you are on the compression stroke when you adjust the valves since this is when they are closed. On the exhaust stroke (depending on where you are) you will have both valves open at some point.
    So, just watch the action of the lifters/valves as you slowly rotate the crankshaft and keep an eye out for the timing mark. Once you see the exhaust valve open then close, followed by the intake opening and closing (intake and exhaust will overlap a bit), keep rotating slowly until the timing mark lines up for TDC.
    Then adjust your valves.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Sep 2013
    ionia michigan
    6
    ty guys for all the help i got fed up with it and took it to a friend
