Results 1 to 3 of 3
Thread: 85-86 250R waterpump weep hole?
    Miami,Fla.(305)
    808
    Just a curious- WHAT IF ?. What WOULD happen IF the weep hole was blocked (intentionally or not) with a present leak on the mech. seal. What happens to the water trying to escape then, would it then take out the oil seal into transm.?? -overheat rite away? or not?.....I know some of you have come across a sealed up weep hole- does it run for a while without a problem?
    I dont have this issue & dont plan on trying this EVER so dont worry-just wondering
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Las Vegas, NV.
    2,532
    It would probably get trapped there in between the waterpump & oil seals, or possibly be forced passed the oil seal and on into the transmission.
    Dec 2007
    Quebec,Canada
    1,014
    I would simply not using it until you install a new seal.Coolant in oil will be long to remove and clean correctly.Doesn't worth a ride.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
