i got this idea from another post but all you guys with TRI-Z 250 trikes know how hard it is to find parts for are machines now a days i think we should have a parts inter changeability post for the TRI-z 250 also. because face it they dont sell jack **** any more for are trikes
these are parts that will bolt up to the TRI-Z 250 that i know of there are many more so help me out guys!
-warrior shock
-banshee shock (must do alot of modifications to make it fit though...)
-YZ125 reeds 88-92
-blaster grab bar (has to be worked a bit)
-banshee rear master cylinder
-any front master cylinder with same threads
-front master cylinder rebuild kits same as warrior, banshee, and raptor
-blaster seat covers (has to be worked a bit)
-banshee front and rear sprockets
-blaster hubs
-warrior hubs
-banshee hubs
-raptor hubs
-YFZ hubs
-86-87 200x hubs (gives you 2 more inches of width)
-honda 300 ex 400ex and 250x hubs bolt up in the rear for more width too (may be a tight fit though)
-83-84 250R hubs
-83-89 YZ250 conecting rod
-85 YZ250 clutch (other years work also)
-85 YZ250 cylinder (other years also)
-85 YZ250 head (other years also)
-YZ250 piston (sleive must be used also)
-250R kicker (slightly modified). Needs shaved down
-banshee rear sprocket hub
-85 YZ250 head gasket (may be thinner so may get more compression)
-banshee axle is the same! can use the carrier if you use a banshee caliper,sprocket hub is the same width and lines up with front sproket,bearing and outer seals use the same part# also
- the 85 BW front fender
-headlight from a 2002 kawasaki bayou 220, The part #'s on the lenses are even the same
-complete hub/axle and front tire off of an 85 200x (front brakes need to be worked a bit)
-bearings and seals from 87-94 yz 250's are the same
-Yamaha Dirtbike Clutch Discs that will fit the TRI-Z 250....
IT250 - 1983
WR250Z - 1994 to 1997
YZ250 - 1982 to 1987
IT490 - 1983 to 1984
YZ490 - 1982 to 1989
WR500Z - 1992 to 1993
-Yamaha Dirtbike Clutch Springs that will fit the TRI-Z 250...
YZ125 - 1989 to 1990
IT250 - 1980 to 1983
WR250F - 2002 to 2005
YZ250 - 1981 to 1984
YZ250 - 1988 to 1992
IT425 - 1980
IT465 - 1981 to 1982
YZ465 - 1980 to 1981
WR500z - 1992 to 1993
XT600 - 1984 to 1989
-Dirtbike Brakes that will fit the TRI-Z 250
YZ125 - 1988 (rear)
RT180 - 1990 to 1997 (front)
TT225 - 1986 to 1987 (front)
TT-R225 - 1999 to 2005 (front)
XT225 - 1992 to 2000 (front)
YZ250 - 1988 (rear)
XT350 - 1985 to 2000 (front)
XT600 - 1990 to 1995 (rear)
-Yamaha ATV Brakes that will fit the TRI-Z 250
YFM350X Warrior - 1987 to 1988 (front)
YFZ350 Banshee - 1987 to 1989 (front)
-ATV Master Cylinder Rebuild Kit that will fit the TRI-Z 250
YFM350X Warrior - 1987 to 1989
YFZ350 Banshee - 1999 to 2004
-87 to 90 old style warrior square headlight housings are the same as tri-z
-banshee blaster voltage regulators all work
-banshee warrior blaster tail lights are direct bolt ons...
- banshee blaster thumb throttles all bolt on,if you use the 86 tri-z thumb cable
-blaster coils and the warrior coil should work also. the warrior has a little longer plug wire on it.
-trx 250 x kickstart
-banshee swingarm bolt
- Calipers:
I know alot of people have been looking for replacement Z calipers, They are now being listed on ebay for alot of money and also there have been alot of wanted adverts for them.
I have done some checking and the Z pads also fit a few other bikes. These are the:
XT350
XT225
TT225
DT125
Warrior
XT600
Out of these I have compared the calipers (from pictures and P/n's)Im 100% sure the XT350 and DT125R (88 onwards) are the same and I am 99% sure that the XT225 and TT225 are a direct bolt up. . I do not have a warrior rear or XT600 to compare so I cannot say if they will work
This should solve the caliper shortage that has been going on and possibly offer some aftermarket ones????
Will
(this is a quote from: slothminx)
SOON MY PRECIOUS!
