Page 8 of 12 FirstFirst ... 6 7 8 9 10 ... LastLast
Results 106 to 120 of 166
Thread: parts that inter change with TRI-Z 250
  1. #106
    Aug 2005
    Lockport, NY
    2,395
    The otha.
    PM Lonesometri-z. He looked into this. It is a 2002 bayou. MUCH CHEAPER than new Tri-z's
  2. #107
    laidout2times is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    SOUTH OF HEAVEN
    180
    I read most of this and Im still unsure if I can bolt on a 87 yz 250 top end to an 86 tri-z. I saw that you can use the cyclinder but must be redone for a yz piston.
    I have a chance to pick up a nice 86 tri-z rider thats 2 over. Also saw a 87yz for sale. Was wondering if its worth picking up for motor parts.
    From what Ive read it seems that MANY year YZ cyclinders/heads can be used. Is this the case? If so what years exactly?
    Has anyone had problems with the fuel pump?
    Thanks in advance for any help. Im amazed Im finding this forum only now.
  3. #108
    Sep 2009
    peoria az
    34
    What about forks I want to put some inverted forks on my tri z I'm getting ready to go and make a triple tree if I have to but that's going to be a major pain tell me plz if u know of any forks that fit perferably an 80cc bikes like rm cr yz I know that certian cr80 forks fit the 250r even the same length so something has to come close for the tri z
  4. #109
    springville, PA
    6,185
    Quote Originally Posted by nitrometh king View Post
    Use the search function because I believe 85z is the same diameter as 200x and 86z is same diameter as 85-86 250R.
    If you have some money to spend contact Jason Hall on the boards. He has done many inverted setups and lots of custom work.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
  5. #110
    Dec 2009
    salt lake city
    3
    new guy here thank's for all the info on here, but i need fender's has anyone had any luck finding any?
  6. #111
    na
    5,702
    Front fenders are available through Maier as well as the rears.
    The rears are also still available OEM and cheaper than Maier.
    Proudly NOT a member of
    "Team on the Teat"
  7. #112
    Dec 2009
    salt lake city
    3
    I did find oem on denniskirk for $176.00. what about shroud's?
  8. #113
    na
    5,702
    With the help of some other members, My wife and I had Maier make molds for the airbox and rad shrouds.
    We have pretty much sold out of them, but I may have a set or 2 left,and I have some used sets as well.
    And we plan on running another batch this spring.
    What color are you looking for? I think I have yellow and black left in new peices.
    here is a link to the special order.
    http://www.3wheelerworldforums.com/s...ad.php?t=82686
    "Team on the Teat"
  9. #114
    Dec 2009
    salt lake city
    3
    yellow shrouds, black tank. It's an early 85. and how about head light plastic's?
  10. #115
    na
    5,702
    I have one set of yellow shrouds left..I will have to check on the tank cover.
    You can PM me for any more info or pricing on those.
    Thanks.
    "Team on the Teat"
  11. #116
    Sep 2008
    845 New York
    2,302
    will an shifter shaft oil seal work from a mid 80s yz250?
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
  12. #117
    Oct 2008
    GA
    4
    just wondering about the shift pedal for a 86 tri-z seems a lot of them are welded. Any other ones a direct swap?
  13. #118
    Nov 2009
    new brunswick
    23
    My forks are bent on my tri z and i cant seem to find them any where is their any other front forks that can be used on the tri z that are just as good if not better
  14. #119
    Nov 2010
    Maine
    29
    very nice thread. I just bought a tri-z today
  15. #120
    Oklahoma
    94
    99-02 Yamaha YFM250 Beartracker shift lever is identical to the z. I have one on mine, works great and it only cost me $15.00 shipped off of ebay.
