Thread: ATC110 Question
    Jul 2012
    Morrow County Ohio
    8
    ATC110 Question
Name:	110 parts bike.jpg
ID:	180815Click image for larger version.
Name:	110 Rebuild.jpg
ID:	180816Click image for larger version.
Name:	110 smokey.jpg
ID:	180817Click image for larger version.
Name:	2013-09-23 19.23.31.jpg
ID:	180818Click image for larger version.
    First I would like to thank the folks that run this site they do a great job!
    I have just acquired 4 ATC 110s, 1980, 1983,1984 and a 1985. 2 are running (84 and 85) 85 needs gasket set (call her smokey) and needs shift lever replaced. She starts first pull no matter how long she sets. The guy I got it from just used perma-tex for gasket. 84 flat out runs great! the 80 is a parts bike. The problem child is the 83. All in time, has great spark but will not fire. Shoots a blue flame out exhaust port. Any ideas? Valves? Haven't adjusted yet. Seems I can't find my feeler gauges. Damn kids..lol
    Any direction would be quite helpful. Thanks in advance,
    JustJimmy
    Jul 2012
    Morrow County Ohio
    8
    Here's my question.... Would the exhaust value being not set to .003 prevent from starting? Found gages and plan on doing this tomorrow any help would be great.Attachment 180866Attachment 180867
    Howdy's Avatar
    Celina, Ohio
    10,079
    It very well could be valves out of adjustment. How ever I would lean more to it being a bent valve. I have seen quite a few 90/110's that the owner put the wrong plug in and bent a valve.
    Howdy
    MNhondaguy's Avatar
    MNhondaguy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2013
    fergus falls, mn
    203
    So, make sure you have the correct plug. Perform the necessary valve adjustments, and then do a wet/dry compression check.
    83 ATC 200E(X) Big Red
    My YouTube- http://m.youtube.com/user/mazdarattiman
    My bros (hoopster3030) YouTube- http://m.youtube.com/user/hoopster3030
