Results 1 to 3 of 3
Thread: 350x not catching compression stroke
    fcf35's Avatar
    fcf35 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2013
    arkansas
    228
    I have two new fixer uppers and they both have the same symptoms.I'm sure their in need of topends because they smoke.my problem is that you can move the kick start until you find the compression stroke and you have to put some pretty good weight on them to kick.once you've made.it through that one it takes several kicks to find another good kick.when its not catching the piston still moves up and down but it feels like there's no compression at all.
    3-350x
    85 250 Bigred
    85 250sx
    85 250r
    Sarnia, Ontario, Canada
    3,415
    Have these engines been sitting for a long time??..perhaps a valve is sticking open.
    I bought a garage stored 200M a couple years back that gave me the same symptom..try a shot of transmission fluid directly into the cylinder and spray some into the carb with the throttle wide open. You'll need an old spray bottle for this..
    The idea would be to get some lubrication at the valve guides. Then kick it over slowly for a while to work it thru..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    fcf35's Avatar
    May 2013
    arkansas
    228
    Yeah they been sitting for a good while.both smoke really bad.I disconnected the decompression cable and still same result.I'm just gonna crack them open and rebuild them.
    3-350x
    85 250 Bigred
    85 250sx
    85 250r
