Results 1 to 15 of 23
Thread: 1984 Honda 200x Kick Start slipping/not engaging fully?!?!
    Nov 2012
    Rhinelander, WI
    10
    Recently picked up the machine from a good friend who's come across a 350X, so he up and gave me his '84 200x. Overall in "ok" condition. Needs a few things to be up to par. Biggest problem I'm having is the kick start won't fully engage. . .like it's slipping. So I pulled the kick start cover off and the gears look great! No wear marks on anything really.
    I heard there should be one or two springs pertaining to the gear assembly? I've been trying to find a parts blow up of the assembly and can't seem to find anything anywhere :/ Not sure what else to do at this point. If someone out there has a diagram they could email me or just post in a reply to this thread that would be fantastic!
    Best Regards to everyone!
    Nov 2012
    Waldoboro, maine
    791
    Hope this helps
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Nov 2012
    Waldoboro, maine
    791
    Hope this helps
    You can download your own manual here:
    http://www.atcmanuals.info/
    Thank Kbonly, he's a member here
    82 250r
    83 Big Red
    85 Auto-x
    Dec 2011
    Grand Rapids, MI.
    679
    If everything looked good when you pulled the cover off then unfortunately you have a bigger issue that will require splitting the case if you want to fix it. The kick starters on these bikes had some design flaws that led to them failing, if you search around there are a lot of threads on the topic.
    1986 KLT 185
    1984 200S
    6,811
    I have the upgraded parts you need to do the repair in stock .
    http://www.3wheelerworld.com/showthr...-S-piston-kits
    Nov 2012
    Rhinelander, WI
    10
    [QUOTE=Bren_downe;1266148]Click image for larger version.
    Hope this helps[/QUOTE
    Quite a bit actually. . .looks like I'm gonna have to split the case :/ Which sucks butt but maybe I can upgrade a few things while doing this
    Nov 2012
    Rhinelander, WI
    10
    shortline10, I would love to purchase improved parts. . .problem is I can't access your page :/ What's the damage for the repair kit and what does it include?
    6,811
    135.00 plus shipping cost .
    Includes 2 new ratchet gears and upgraded stronger ratchet spring .
    Quote Originally Posted by HNDA125M View Post
    Sep 2011
    New Castle, PA
    1,134
    Before you do that, check your splines! I had the same problem, and my kicker screw wasnt tightened enough and the splines werent gripping.
    Do this. Whenever it 'slips', can you bring the kicker back up without noise? If yes, then its something internal. If no, check your splines.
    1983 212x "Mickey Dunlap" Powroll TT Trike -Blue frame, Supertrapp (looking for a Powroll DD), WEB Stage II cam, Powroll 6mm stroker, Wiseco 10.25:1 piston stock bore, ported, polished, +2 Swinger,White low-pros and 250R front fender, BAPP rear shock, Powroll Decals, NOS Carlisle R/A's
    Gone:
    '83 185s, '86 200x, '70's Full Suspension Hi-Performance ATC RD400,
    Mar 2013
    Minnesota
    441
    same problem i have. one of the kickstarter gears binded or broke teeth off and are not catching. split the case and the job will become apparent.
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
    Nov 2012
    Rhinelander, WI
    10
    Thanks for the input guys! I'll start on it at some point this week and I'll keep ya's updated!
    6,811
    If its the tranny side of the kicker gears yes it will be obvious and missing teeth BUT if its ratchet teeth that are worn its hard to tell and defiantly not apparent .
    Quote Originally Posted by honda200xguy View Post
    Nov 2012
    Rhinelander, WI
    10
    Just found out yesterday the friend I got the machine from backed off a "set bolt" located in the backside of the case. Also found out there's a flat spot on the secondary shaft for this bolt to seat and hold one of the springs in place. . .thinking I may have found the problem before even diving into it. . .fingers crossed though :/ Haven't had a chance to do the split yet. Trying to find a heater for the garage, nothing worse than working with cold tools :/ lol
    Dec 2015
    Port Robinson
    7
    200x slipping kickstarter
    I found an old post regarding slipping 200x kickstarter . If you still have repair parts,I'd really like to buy them.Really want to keep the old 200x manual clutch instead of swapping auto engine . I tried to PM ,but I guess that my new member status won't allow ? Thankyou , Tim
    6,811
    Email me at shortlynx@earthlink.net if you need a kit .
    Mike
