I have an 82 and 84 stock atc 70's, they sat for a while, I cleaned the carbs, and fresh gas, they will idle and rev out, but when I shift into 1st gear they bogg out and die. is this electrical? any help would be great. thanks in advance.
check the points gap
Try gaping the points and replace the spark plug. I have seen condensers fail, the motor will run idle and rev but once you put a load on the motor it stalls. Does your motor have a neutral switch. Some of the Honda " replacement " motors had neutral switches. That may also cause a problem.
Trikes:
1985 ATC 70 mod to 184cc
1984 ATC70 mod to 124cc
1983 ATC 70 Xmas restoration
Quads:
1986 TRX 250R
2002 TRX 400EX
2- LT80 for the kids
1986 LT 50
