Keep the info rollin!
I love my sped for what it is, just wish it had a few more nuts in the sack. I find theres certain instances i cant make it up certain hills due to being stuck in first or second and just plain lose momentum.
I am also interested in seeing the best place for an oil cooler and a good one to purchase for the es/sx.
I'd like to have an oil cooler on my trx300. I'd love to do a big bore on an es/sx.
Having reviewed the oil flow diagram in the manual I think it may be a tricky install..
Installing in the oil feeder I believe would be a bad plan as the extra plumbing might create more resistance to flow that might cause oil starvation to the head.
I may take a scrap right engine cover and drill into it to locate the main feeder tube near the filter housing..once located a careful drill and tap to install in/out flow nipples to route to the cooler.
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
This is the idea I had Mickey, if I understand, it's close to what you had in mind..??
Catch the oil feed away from the pump and before it hits the filter..line out to the cooler, then back before the filter. I've have to close off the feed channel between somehow to force the oil to route thru the cooler..
From this point the post filter oil should be cooled by 40-50' before it 'Y's off to the upper and lower parts of the engine.
Current toys..
1990 Honda TRX300FW
1995 Seadoo GTX
I've seen the filter covers drilled and tapped directly in the center, and again in the top of it (if memory serves) and the cooler hooked up that way. I had thought about removing the stock oil line from the crankcase to the head, and using steel braided lines with banjo fittings to re-use the factory banjo bolts and hook the cooler up between the crankcase and head... Like Mickey said, the cam and rockers get the most, if not all, the abuse in the old Hondas.
I've thought about doing that, but, I don't like rubber lines on an off road vehicle. I used steel braided lines on my Warrior's clutch cover cooler I did. The stock size banjos did concern me when it comes to the line size, cooler size, and distance the oil would have to travel vs. the volume the stock banjos can supply for all that.
How much more heat should be expected? I dont have any issues with my sped getting hot in its stock form, even at pokin speeds
A little constructive suggestions for you Mickey as I was one of those who visited your site last night. Quite by accident I might add..I googled for kits and found the site not knowing it was yours.
I found the product listing very lacking in information, no photos of the kits, no description of what the kit includes..
The cool flash animation of the garage door was great but it's the product I came to see not that. The site was pretty cookie-cutter with more than a few 'under construction' pages..
Not 'everyone wants to build their own as cheap as they can'..that includes me, I'm not a cheap guy!
When I'm random web shopping I look for a well designed page with detailed product information and pictures, after all it is what the buyer has to go on..I guess "Oil Kit Cooler $85.00" didn't grab my attention, my ADD kicked in and I left the page!
Example: FlyingW(Jim) posted some killer pics of his rebuilt carbs some months ago and I knew right away I had to have one..I think I've had 3 total now!!
Show me the product, I'd love to show the money!
Not trying to offend, just give a subjective review of why a good number of people might be 'walking into your store and then leaving'..you may consider a rebuild!
Current toys..
1990 Honda TRX300FW
1995 Seadoo GTX
True. Lots of people use rubber hoses. I just don't trust them not to get snagged by all the briers I ride through around here. I've had gashes cut into tires by them suckers. Steel braided lines look much cooler, too. Lol. Yes, your cooling method works very well for the Warrior. I ran the Big Bear method for about a year on my stock stroke engine. No complaints, but, I can tell the clutch cover method runs cooler.
