Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 41
Thread: Big Red accessory outlet
    Mar 2013
    Central PA
    2,362
    What have you guys used yours for? I know some people wired in a 12v cigarette lighter thing in there, but im wondering what are some of the more unique uses people have tried. Or what you used the lighter outlet for.
    Also, i know they made the Hondaline spot light, but people said they made some other things in the threads i have seen about this subject, yet nobody knows exactly. I mean they must have made more things, its a honda specific accessory plug.
    Im getting a nice 200e tomorrow so thats why im curious. My first big red.
    MNhondaguy's Avatar
    MNhondaguy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2013
    fergus falls, mn
    203
    I was always wondered what plugged into there, until I found this site and seen the brochure about the honda line stuff. I have wired in the regular 12v flat2 plug and used a sprayer and such, but that's about it.
    83 ATC 200E(X) Big Red
    My YouTube- http://m.youtube.com/user/mazdarattiman
    My bros (hoopster3030) YouTube- http://m.youtube.com/user/hoopster3030
    Nov 2004
    Waterloo IL
    2,701
    I need to add one to a Scrambler! Good for charging a cell phone!
    Mar 2013
    Texas
    42
    GHOSTv2,
    I do not want to highjack your thread, but my 250SX has a 12V accessory plug and from the looks of it, it is a dealer add on?? Reason I say this is, I bought this machine from the original owner being an older gentleman and it is bone stock from back to front. If you look at the wiring it is just too clean to be an added accessory after original purchase? THoughts? I keep a small air pump in the rear trunk compartment and it works like a charm!Click image for larger version.
ID:	181307Click image for larger version.
ID:	181308Click image for larger version.
ID:	181309Click image for larger version.
    Jun 2006
    holland, ohio
    1,587
    Sorry to inform you but the 200 Big Red doesn't have the power outlet. It was a stock item on the 85-87 250es. I have the Hondaline spotlight that plugs into it.
    Hampton, Virginia, C.S.A.
    2,664
    i wired a little water proof 12v radio off ebay to my outlet. works good
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Enumclaw WA
    89
    I ran a spotlight off mine when I had one. I just cut the plug off the light and use some wire connecters that fit the accessory plug. It worked good.
    Mar 2013
    Central PA
    2,362
    Quote Originally Posted by ditchmud View Post
    Well anyways, still want to see what some people have come up with and used. I thought at least the 200es came with it. Didnt know if the 200e did. Would you still be able to put one in somehow?
    Quote Originally Posted by rooster67 View Post
    GHOSTv2,
    I had no idea the 250sx came with an accessory plug, let alone an outlet like that. Im guessing someone did it, not stock. But it looks like it was done really good, very clean. Looks nice enough to belong there.
    Mar 2011
    Red Lion pa
    1,542
    The 84 200es did. The one I parted out had one on it. Also shown on the parts explosion. Item #13.
    http://www.partzilla.com/parts/searc...IER/parts.html
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    Mar 2013
    Central PA
    2,362
    This is my 1983 200e i just got minutes ago and that looks to be a 12v accessory outlet.
    MN
    3,263
    I haven't seen a 200E or 200ES yet that didn't have it. The 250 wasn't the only one with it. I have even seen it on a 200M, but it may have been added by a previous owner not sure if it was entirely stock on that model.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    MN
    3,263
    Quote Originally Posted by Ghostv2 View Post
    Nice, even has the weather cover still! I use mine for a bunch of things, although i replaced it with a standard lighter socket so its more versatile. I have run radios, little air compressor that rides with me, drill charger, cell phone charger, spotlight, rechargeable flashlight, etc etc.. Just remember to keep the motor runnin if you run much off it, will drain the battery pretty quickly, and for more amperage while using it shut the lights off so they aren't taking most of your amps.
    I also have a cigarette lighter outlet in the trunk, nice place to plug in and store my phone.
    Mar 2013
    Central PA
    2,362
    That's a really cool idea to have it in the trunk and the whole cell phone setup. How did you wire it up? I kinda don't wanna butcher this outlet. So If I can wire one up in the back it'd be great. Or even better yet , if someone made adapters for them.
    Dec 2012
    812
    As mentioned the Big Red 200 did have the power outlet installed from the factory.
    Lots of interesting uses for the outlet mentioned here. I was thinking it may be a good spot to connect handle grip heaters?
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Mar 2013
    Central PA
    2,362
    Im still wondering what else they made for it. I mean, it was used for 5 years through 3 different models and they only made a spotlight? Weird.
    But like all Hondaline accessories for the ATC, they are hard to find and expensive.
