Results 1 to 7 of 7
Thread: will 25 inch tires fit on a 1983 honda 185s
    Nov 2013
    ishpeming michigan
    15
    Hello had a question been looking at a 83 honda 185s and was wondering if 25 inch tires will work on it the 22 inch ones on it now are no good if not what modifications would have to be done for them to fit thanks
    Nov 2013
    ishpeming michigan
    15
    Anyone with info on this
    Sarnia, Ontario, Canada
    3,415
    Nope, since the 25s are for a 9" rim, the stock 185s rim with 22s are an 8" rim.
    Buy a new pair of 22x11x8 tires and install them on the stock rims..you're golden!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Nov 2013
    ishpeming michigan
    15
    Will the 9 inch rims bolt on to the 185s
    Aug 2013
    Princeton, IN
    41
    nope rear hub's are too small and the front end is not wide enough for a 25"wheel
    3,415
    Quote Originally Posted by daytripper View Post
    You could mount them on the rear if you found some hubs of the same bolt pattern that fit you axle..I believe the standard 200x rear hubs are a direct fit and will get those wheels on. That is assuming 25s are off of a 250 Big Red with 4/110 bolt pattern..
    You haven't given us those details!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Jul 2013
    mo
    327
    If u do go with bigger tires , slow way down . That thing will be so bouncy , it will death wobble at high speed and some bumps . I almost snapped my spine when to much speed meets bouncy big tires and over the bars I went and my 185 landed on me . Got lucky. It would scream with 400ex rimes and tires . Not sure if hubs will work .
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
